I want to use the ALFAT SD board in an upcoming project. I was looking at the pinout of the 1x16 connector and noticed that there is no power input pin. Is it intended that both the 1x16 and 2x5 connector would be required to get all the necessary signals? I want to use the wakeup pin which is on the 1x16 and the power which is on the 2x5. Any ideas?
The manual is mislabeled. This is a copy/paste error from the USBwiz-OEM pinout.
Pin 13 is the 3.3V power pin.
