Good afternoon,
I am using the Alfat Explorer, sadly I can not tell you which version because when I click on the ABOUT menu item, it does not give a revision number. Just a copyright number (2014). Anyway, using the Miscellaneous tab, if you click on the “RTC Battery” the command shown in the window is “T S”, in the manual the “T S” command describes shared mode, not backup mode. Also if you click on RTC Internal, the command shown is “T B”. I would assume the manual is correct, and backup is implemented with the “T B” command, correct? Please confirm. You guys may want to fix the explorer software.
