Alfat 2 I2C_busy signal stuck high
Hello!
I am currently having trouble with the Alfat 2.
First, I read the banner from the Alfat chip.
Then I mount the USB device as “U0:”
I proceed to append to a nonexistent file. It is then created in the process.
After sending about 2100 bytes to the Alfat the I2C_busy signal goes high and stays high. In the firmware I have a loop that waits until the I2C_busy line goes low before I send my data. I have waited for several minutes but it remains high.
In this application I was previously using the Alfat 1 but after the discontinuation I switched to the Alfat 2. That is when this problem began to appear.
This is on a custom board, but I have verified that electrically it is sound.
What exactly is the procedure when the I2C_busy line goes high? Have I missed something in the datasheet about the I2C protocol?
Thanks!
@ t11230 -
it is not happened in ALFAT1 but happened in ALFAT 2?, does that what you mean?
The busy pin does only go high when the buffer is bigger than 4K OR read/write data to media.
