how to use Aforge .net framework in fez spider? when i add refernence Aforge Dll and build the Application
Error 2 Unable to copy file "E:\D drive Back up\software\Aforge\Samples\Imaging\BlobsExplorer\bin\Debug\LE\AForge.Imaging.pe" to "bin\Debug\LE\AForge.Imaging.pe". Could not find a part of the path 'E:\D drive Back up\software\Aforge\Samples\Imaging\BlobsExplorer\bin\Debug\LE\AForge.Imaging.pe'. AF
this type of error generated. how can i get .pe and .le files for Aforge?
No, it means that a standard .net compiled “object” is not transportable onto netmf. not just aforge, whatever that is.
Remember, there’s lots of things the netmf does not do; it is designed for embedded devices with limited memory and slow processors (when compared to PC’s and their software).
@ biren - You can take the portion you are interested in from AForge and recompile it for .NetMF. You will probably need to do some small changes, but it is doable.
AForge is a library to do things like computer vision, neural networks, genetic programming, and machine learning. Even if you have the source (and you do; it’s open source), your NETMF device doesn’t have the horsepower to accomplish these tasks in any reasonable amount of time.
