Having a few small systems running for test I have realized that my lab power suplly does a fine job.
But putting those systems into operation requires a power supply of a more generic type, with reasonable capacity. Being able to suply at least 3A and supplying both 3,3V and 5V. The input is going to vary from 8 to 48V.
Searching ebay for this gives quite a wide array of choices: [url]module for sale | eBay
I have managed to be satisifed with USB-DP so far, but I would some more connection points and possible screw terminals that fits well in a mash-up of several systems.
I have a current limiting, digital voltmeter/ammeter unit for early startup of projects (can’t find it easily on ebay but another cheapie, from memory ~$10).
Other than that, I’ll use a SP or DP module, or even power from USB if needed. In a Frankenstein product, I’d probably opt to use multiple of the first power modules if I needed more power than I could get thru perhaps one of those and an LM1117 onboard 3v3 regulator, or needed different voltages. They are quite effective, much better than a straight linear regulator
