Thank you very much. Sadly i read most of them already before. But somehow i was not able to find the right answer to connect those doc’s to my FEZ Cebruino.
Somehow i find what is was looking for and now it was a peace of cake.
I made changes to it as well. Now the lib does only work for stepper motors.
Sadly my stepper motor did not want to rotate yet. But i think thats because the power supply.
using GHI.OSHW.Hardware;
//using GHI.Premium.Hardware;
//using GHIElectronics.NETMF.FEZ;
namespace Mshield
// Initialize both driver on Motor Shield
Mshield MyMotors = new Mshield(Mshield.Drivers.Stepper,Mshield.Drivers.None);
// Create servo motors (not used in this example)
// pin.PWM servo1 = new pin.PWM(MyMotors.Servo1);
// PWM servo2 = new PWM(MyMotors.Servo2);
// Blink board LED
bool ledState = false;
OutputPort led = new OutputPort((Cpu.Pin)FEZCerbuino.Pin.Digital.LED1, ledState);
ledState = !ledState;
led.Write(ledState);
// We have one stepper connected on driver1 (M0/M1)
// Have it run 5s in "Hi-Torque" (High power, high speed, high power usage...)
MyMotors.StepperMove(Mshield.Steppers.S1, 0, true, 0, 5000, false);
Thread.Sleep(1000);
// Then 5s in the other direction
MyMotors.StepperMove(Mshield.Steppers.S1, 0, false, 0, 5000, false);
Thread.Sleep(1000);
/* Adafruit motor "Shield v1.0" / See: <a href="http://www.ladyada.net/make/mshield/index.html" target="_blank">http://www.ladyada.net/make/mshield/index.html</a>
* Driver v0.1a - Copyright 2011 Nicolas Ricquemaque
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* <a href="http://www.apache.org/licenses/LICENSE-2.0" target="_blank">http://www.apache.org/licenses/LICENSE-2.0</a>
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
* The Adafruit Motor Shield can drive up to four motors (including speed and direction)
* or max 2 steppers motors (each stepper using one of the 2 shield drivers, instead of 2 motors).
* Two servo connectors are available on the shield, directly from pins DI9 and DI10 (no control
* of servos is made by the board or by this driver, however there use is simple, just look at the
* beginner's guide).
* Due of timing constraints, no micro-stepping is performed
* (that would need RLP programming which we are not doing here)
* The handling of stepper motors is blocking untill the action requested is completed
* However, this is not the case for simple motors: just set a state, and the motor will keep it.
* Please report bugs to f1iqf (at) hotmail (dot) com
public class Mshield : IDisposable
public enum Drivers : byte { None = 0, Stepper}
public enum Steppers : byte { S1 = 0, S2 }
public enum BipolarStepping : byte { WaveDrive = 0, HiTorque, HalfStep }
public BipolarStepping mode = BipolarStepping.WaveDrive;
/// On board Servo1 connector, for external reference only
public PWM Servo1 = new PWM(FEZCerbuino.Pin.PWM.D9, 20000, 1500, PWM.ScaleFactor.Microseconds, false);//PWM( FEZCerbuino.Pin.PWM.D9,);
/// On board Servo2 connector, for external reference only
public PWM Servo2 = new PWM(FEZCerbuino.Pin.PWM.D10, 20000, 1500, PWM.ScaleFactor.Microseconds, false);//(PWM.Pin)FEZ_Pin.PWM.Di10;
private Drivers[] UsedDriver = new Drivers[] {Drivers.None,Drivers.None};
private OutputPort Motor1A, Motor1B; // Enable L293D driver #1a and #1b
private OutputPort Motor2A, Motor2B; // Enable L293D driver #1a and #1b
private OutputPort MotorLatch, MotorEnable, MotorClk, MotorData; // 74HCT595 commands
byte latch_state; // Actual 74HCT595 output state
// Steper sequences for each stepper. Have a look here : <a href="http://www.stepperworld.com/Tutorials/pgBipolarTutorial.htm" target="_blank">http://www.stepperworld.com/Tutorials/pgBipolarTutorial.htm</a>
private byte[][] BipolarSteppingWaveDrive = new byte[][] { new byte [] {4,2,8,16},
new byte [] {1,128,64,32}};
private byte[][] BipolarSteppingHiTorque = new byte[][] { new byte [] {20,24,10,6},
new byte [] {129,192,96,33}};
private byte[][] BipolarSteppingHalfStep = new byte[][] { new byte [] {4,20,16,24,8,10,2,6},
new byte [] {1,129,128,192,64,96,32,33}};
private byte[] lastpos = new byte[] { 0, 0 };
/// Constructor
/// Which driver to initialize : 1=driver 1, 2=driver 2, 3=both
public Mshield(Drivers driver1 = Drivers.None, Drivers driver2 = Drivers.None)
UsedDriver[0] = driver1;
UsedDriver[1] = driver2;
if (driver1 != Drivers.None)
Motor1A = new OutputPort((Cpu.Pin)FEZCerbuino.Pin.Digital.D11, false);
Motor1B = new OutputPort((Cpu.Pin)FEZCerbuino.Pin.Digital.D3, false);
if (driver2 != Drivers.None)
Motor2A = new OutputPort((Cpu.Pin)FEZCerbuino.Pin.Digital.D5, false);
Motor2B = new OutputPort((Cpu.Pin)FEZCerbuino.Pin.Digital.D6, false);
/* Motor2A = new PWM(FEZCerbuino.Pin.PWM.D5, 20000, 1500, PWM.ScaleFactor.Microseconds, false);//new PWM((PWM.Pin)FEZ_Pin.PWM.Di5);
Motor2A.Stop();// (false);
Motor2B = new PWM(FEZCerbuino.Pin.PWM.D6, 20000, 1500, PWM.ScaleFactor.Microseconds, false);//new PWM((PWM.Pin)FEZ_Pin.PWM.Di6);
Motor2B.Stop();// Set(false);*/
MotorLatch = new OutputPort((Cpu.Pin)FEZCerbuino.Pin.Digital.D12, true);
MotorEnable = new OutputPort((Cpu.Pin)FEZCerbuino.Pin.Digital.D7, false);
MotorClk = new OutputPort((Cpu.Pin)FEZCerbuino.Pin.Digital.D4, true);
MotorData = new OutputPort((Cpu.Pin)FEZCerbuino.Pin.Digital.D8, true);
latch_state = 0;
latch_tx();
#region IDisposable Members
public void Dispose()
latch_state = 0;
latch_tx();
if (UsedDriver[0] != Drivers.None)
Motor1A.Dispose();
Motor1B.Dispose();
if (UsedDriver[1] != Drivers.None)
Motor2A.Dispose();
Motor2B.Dispose();
MotorLatch.Dispose();
MotorEnable.Dispose();
MotorClk.Dispose();
MotorData.Dispose();
#endregion IDisposable Members
// Send byte to the 74HCT595 demux
private void latch_tx() {
MotorLatch.Write(false);
for (int i = 8; i >= 0 ; i--)
MotorClk.Write(false);
MotorData.Write((latch_state & (1 << i)) > 0);
MotorClk.Write(true);
MotorLatch.Write(true);
/// Move a stepper. Only one param between steps and msec but be set different from 0.
/// Blocking call.
/// Which stepper to drive
/// Stepping mode
/// Number of ms between each step (0 : no pause=max speed)
/// True = foward, False = backward
/// If non-zero, number of steps to run
/// If non-zero, number of ms to run
/// True if stepper shall stay energized when task done
/// Number of steps ran
public uint StepperMove(Steppers which, int speed, bool direction, int steps, int msec, bool hold = false)
if (UsedDriver[(byte)which] == Drivers.None) return 0;
// Find where we stopped last time
byte last = lastpos[(byte)which];
int pos ;
uint step = 0;
byte[] MotorSteps = BipolarSteppingWaveDrive[(byte)which]; // Get the stepping pattern
if (mode == BipolarStepping.HiTorque) MotorSteps = BipolarSteppingHiTorque[(byte)which];
if (mode == BipolarStepping.HalfStep) MotorSteps = BipolarSteppingHalfStep[(byte)which];
if (which == 0)
last = (byte)(latch_state & 0x1E);
last = (byte)(latch_state & 0xE1);
for (pos = 0; pos < MotorSteps.Length; pos++)
if (MotorSteps[pos] == last) break;
if (pos == MotorSteps.Length) pos = 0;
if (which == 0) {
Motor1A.Write(true); Motor1B.Write(true);
} else {
Motor2A.Write(true); Motor2B.Write(true);
byte Mask = (byte)((which == 0) ? 0xE1 : 0x1E);
if (steps > 0) // user chose to move from a number of steps
for (; step < steps; step++)
if (direction) pos = (pos + 1) % MotorSteps.Length;
else if (--pos < 0) pos = MotorSteps.Length - 1;
latch_state = (byte)((latch_state & Mask) | MotorSteps[pos]);
latch_tx();
if (speed > 0) Thread.Sleep(speed);
else // So no number of steps, the user must have given a time to run
long endtime = DateTime.Now.Ticks + msec * TimeSpan.TicksPerMillisecond;
for (; DateTime.Now.Ticks < endtime; step++)
latch_tx();
if (!hold) // Remove energy from stepper
if (which == 0)
Motor1A.Write(false); Motor1B.Write(false); }
Motor2A.Write(false); Motor2B.Write(false);
return step;
