For anyone interested in this piece of hardware here is some code that might help.
Driver Code:
using GHIElectronics.TinyCLR.Devices.I2c;
using GHIElectronics.TinyCLR.Devices.Spi;
using System.Collections;
using System.Diagnostics;
using System.Text;
namespace Sample
public enum ST7735CommandId : byte
//System
NOP = 0x00,
SWRESET = 0x01,
RDDID = 0x04,
RDDST = 0x09,
RDDPM = 0x0A,
RDDMADCTL = 0x0B,
RDDCOLMOD = 0x0C,
RDDIM = 0x0D,
RDDSM = 0x0E,
SLPIN = 0x10,
SLPOUT = 0x11,
PTLON = 0x12,
NORON = 0x13,
INVOFF = 0x20,
INVON = 0x21,
GAMSET = 0x26,
DISPOFF = 0x28,
DISPON = 0x29,
CASET = 0x2A,
RASET = 0x2B,
RAMWR = 0x2C,
RAMRD = 0x2E,
PTLAR = 0x30,
TEOFF = 0x34,
TEON = 0x35,
MADCTL = 0x36,
IDMOFF = 0x38,
IDMON = 0x39,
COLMOD = 0x3A,
RDID1 = 0xDA,
RDID2 = 0xDB,
RDID3 = 0xDC,
//Panel
FRMCTR1 = 0xB1,
FRMCTR2 = 0xB2,
FRMCTR3 = 0xB3,
INVCTR = 0xB4,
DISSET5 = 0xB6,
PWCTR1 = 0xC0,
PWCTR2 = 0xC1,
PWCTR3 = 0xC2,
PWCTR4 = 0xC3,
PWCTR5 = 0xC4,
VMCTR1 = 0xC5,
VMOFCTR = 0xC7,
WRID2 = 0xD1,
WRID3 = 0xD2,
NVCTR1 = 0xD9,
NVCTR2 = 0xDE,
NVCTR3 = 0xDF,
GAMCTRP1 = 0xE0,
GAMCTRN1 = 0xE1,
public enum Buttons
BUTTON_UP_PIN = 1 << 2,
BUTTON_LEFT_PIN = 1 << 3,
BUTTON_DOWN_PIN = 1 << 4,
BUTTON_RIGHT_PIN = 1 << 7,
BUTTON_B_PIN = 1 << 9,
BUTTON_A_PIN = 1 << 10,
BUTTON_SELECT_PIN = 1 << 11,
ALL = (1 << 2) | (1 << 3) | (1 << 4) | (1 << 7) | (1 << 9) | (1 << 10) | (1 << 11)
//Used for raising button events
public delegate void ButtonStateChangedEventHandler(Buttons button, bool newState);
public class AdafruitMiniTFTWithJoystickFeatherwing
private readonly byte[] buffer1 = new byte[1];
private readonly byte[] buffer4 = new byte[4];
private readonly SpiDevice spi;
private readonly I2cDevice _i2cDevice;
private readonly GpioPin control;
const byte ST77XX_MADCTL_MY = 0x80;
const byte ST77XX_MADCTL_MX = 0x40;
const byte ST77XX_MADCTL_MV = 0x20;
const byte ST77XX_MADCTL_ML = 0x10;
const byte ST77XX_MADCTL_RGB = 0x00;
const byte SEESAW_STATUS_BASE = 0x00;
const byte SEESAW_STATUS_SWRST = 0x7F;
const byte SEESAW_GPIO_BASE = 0x01;
const byte SEESAW_TIMER_BASE = 0x08;
* GPIO module function addres registers
const byte SEESAW_GPIO_DIRSET_BULK = 0x02;
const byte SEESAW_GPIO_DIRCLR_BULK = 0x03;
const byte SEESAW_GPIO_BULK = 0x04;
const byte SEESAW_GPIO_BULK_SET = 0x05;
const byte SEESAW_GPIO_BULK_CLR = 0x06;
const byte SEESAW_GPIO_PULLENSET = 0x0B;
* status module function addres registers
const byte SEESAW_STATUS_HW_ID = 0x01;
const byte SEESAW_TIMER_PWM = 0x01;
const byte SEESAW_HW_ID_CODE = 0x55;
int _colstart = 24;
int _rowstart = 0;
int MaxWidth = 80;
int MaxHeight = 160;
public int Height => 80;
public int Width => 160;
//Seesaw reset pin
const int _resetPin = 1 << 8;
int _lastPressed = 0;
private int _xstart;
private int _ystart;
private int _width;
private int _height;
public event ButtonStateChangedEventHandler OnButtonStateChanged;
public AdafruitMiniTFTWithJoystickFeatherwing(I2cController controller, SpiController spiController, GpioPin chipSelect, GpioPin control, int debounceMs = 50)
spi = spiController.GetDevice(new SpiConnectionSettings
Mode = SpiMode.Mode3,
ClockFrequency = 12_000_000,
ChipSelectType = SpiChipSelectType.Gpio,
ChipSelectLine = chipSelect
_i2cDevice = controller.GetDevice(new I2cConnectionSettings(0x5E));
this.control = control;
this.control.SetDriveMode(GpioPinDriveMode.Output);
Initialize();
//Thread used to read the seesaw pin values and raise event as needed
new Thread(() =>
var buttons = (int)(Buttons.BUTTON_UP_PIN | Buttons.BUTTON_DOWN_PIN | Buttons.BUTTON_LEFT_PIN | Buttons.BUTTON_RIGHT_PIN | Buttons.BUTTON_SELECT_PIN | Buttons.BUTTON_A_PIN | Buttons.BUTTON_B_PIN);
if (debounceMs < 20)
debounceMs = 20;
var buffer = new byte[8];
_i2cDevice.Write(new byte[] { SEESAW_GPIO_BASE, SEESAW_GPIO_BULK });
_i2cDevice.Read(buffer);
int ret = (buffer[0] << 24) | (buffer[1] << 16) | (buffer[2] << 8) | buffer[3];
var active = (int)buttons - (ret & buttons);
if (active != _lastPressed)
var isPressed = active > _lastPressed;
var diff = isPressed ? active - _lastPressed : _lastPressed - active;
if (diff >= (int)Buttons.BUTTON_SELECT_PIN)
OnButtonStateChanged?.Invoke(Buttons.BUTTON_SELECT_PIN, isPressed);
diff -= (int)Buttons.BUTTON_SELECT_PIN;
if (diff >= (int)Buttons.BUTTON_A_PIN)
OnButtonStateChanged?.Invoke(Buttons.BUTTON_A_PIN, isPressed);
diff -= (int)Buttons.BUTTON_A_PIN;
if (diff >= (int)Buttons.BUTTON_B_PIN)
OnButtonStateChanged?.Invoke(Buttons.BUTTON_B_PIN, isPressed);
diff -= (int)Buttons.BUTTON_B_PIN;
if (diff >= (int)Buttons.BUTTON_RIGHT_PIN)
OnButtonStateChanged?.Invoke(Buttons.BUTTON_RIGHT_PIN, isPressed);
diff -= (int)Buttons.BUTTON_RIGHT_PIN;
if (diff >= (int)Buttons.BUTTON_DOWN_PIN)
OnButtonStateChanged?.Invoke(Buttons.BUTTON_DOWN_PIN, isPressed);
diff -= (int)Buttons.BUTTON_DOWN_PIN;
if (diff >= (int)Buttons.BUTTON_LEFT_PIN)
OnButtonStateChanged?.Invoke(Buttons.BUTTON_LEFT_PIN, isPressed);
diff -= (int)Buttons.BUTTON_LEFT_PIN;
if (diff >= (int)Buttons.BUTTON_UP_PIN)
OnButtonStateChanged?.Invoke(Buttons.BUTTON_UP_PIN, isPressed);
diff -= (int)Buttons.BUTTON_UP_PIN;
_lastPressed = active;
Thread.Sleep(debounceMs);
}).Start();
private void Initialize()
#region Seesaw initialization
_i2cDevice.Write(new byte[] { SEESAW_STATUS_BASE, SEESAW_STATUS_SWRST, 0xFF });
Thread.Sleep(1000);
var buffer = new byte[1];
_i2cDevice.Write(new byte[] { SEESAW_STATUS_BASE, SEESAW_STATUS_HW_ID });
if (buffer[0] != SEESAW_HW_ID_CODE)
throw new Exception("Did not find device");
var buttons = Buttons.BUTTON_UP_PIN | Buttons.BUTTON_DOWN_PIN | Buttons.BUTTON_LEFT_PIN | Buttons.BUTTON_RIGHT_PIN | Buttons.BUTTON_SELECT_PIN | Buttons.BUTTON_A_PIN | Buttons.BUTTON_B_PIN;
WritePinMode((int)buttons, 3);
OnButtonStateChanged?.Invoke(Buttons.ALL, false);
Thread.Sleep(100);
WritePinMode(_resetPin, 1);
#endregion
#region ST7735 initialization
//Reset ST7735
DigitalWrite(_resetPin, true);
Thread.Sleep(50);
DigitalWrite(_resetPin, false);
Thread.Sleep(50);
SendCommand(ST7735CommandId.SWRESET);
Thread.Sleep(120);
SendCommand(ST7735CommandId.SLPOUT);
Thread.Sleep(120);
SendCommand(ST7735CommandId.FRMCTR1);
SendData(0x01);
SendData(0x2C);
SendData(0x2D);
SendCommand(ST7735CommandId.FRMCTR2);
SendData(0x01);
SendData(0x2C);
SendData(0x2D);
SendCommand(ST7735CommandId.FRMCTR3);
SendData(0x01);
SendData(0x2C);
SendData(0x2D);
SendData(0x01);
SendData(0x2C);
SendData(0x2D);
SendCommand(ST7735CommandId.INVCTR);
SendData(0x07);
SendCommand(ST7735CommandId.PWCTR1);
SendData(0xA2);
SendData(0x02);
SendData(0x84);
SendCommand(ST7735CommandId.PWCTR2);
SendData(0xC5);
SendCommand(ST7735CommandId.PWCTR3);
SendData(0x0A);
SendData(0x00);
SendCommand(ST7735CommandId.PWCTR4);
SendData(0x8A);
SendData(0x2A);
SendCommand(ST7735CommandId.PWCTR5);
SendData(0x8A);
SendData(0xEE);
SendCommand(ST7735CommandId.COLMOD);
SendData(0x05);
SendCommand(ST7735CommandId.VMCTR1);
SendData(0x0E);
SendCommand(ST7735CommandId.GAMCTRP1);
this.SendData(new byte[] { 0x02, 0x1c, 0x07, 0x12, 0x37, 0x32, 0x29, 0x2d, 0x29, 0x25, 0x2B, 0x39, 0x00, 0x01, 0x03, 0x10 });
SendCommand(ST7735CommandId.GAMCTRN1);
this.SendData(new byte[] { 0x03, 0x1d, 0x07, 0x06, 0x2E, 0x2C, 0x29, 0x2D, 0x2E, 0x2E, 0x37, 0x3F, 0x00, 0x00, 0x02, 0x10 });
SendCommand(ST7735CommandId.NORON);
Thread.Sleep(10);
SendCommand(ST7735CommandId.MADCTL);
SendData(0xC0);
SetRotation(3);
SetDrawWindow(0, 0, _width, _height);
SetBacklightIntensityPercentage(100);
#endregion
public void Dispose()
spi.Dispose();
control.Dispose();
public void Enable() => SendCommand(ST7735CommandId.DISPON);
public void Disable() => SendCommand(ST7735CommandId.DISPOFF);
private void SendCommand(ST7735CommandId command)
buffer1[0] = (byte)command;
control.Write(GpioPinValue.Low);
spi.Write(buffer1);
private void SendData(byte data)
buffer1[0] = data;
control.Write(GpioPinValue.High);
spi.Write(buffer1);
private void SendData(byte[] data)
spi.Write(data);
void SetRotation(byte rotate)
byte madctl;
switch (rotate)
case 1:
madctl = ST77XX_MADCTL_MY | ST77XX_MADCTL_MV | ST77XX_MADCTL_RGB;
_width = MaxHeight;
_height = MaxWidth;
_ystart = _colstart;
_xstart = _rowstart;
break;
case 2:
madctl = ST77XX_MADCTL_RGB;
_height = MaxHeight;
_width = MaxWidth;
_xstart = _colstart;
_ystart = _rowstart;
break;
case 3:
madctl = ST77XX_MADCTL_MX | ST77XX_MADCTL_MV | ST77XX_MADCTL_RGB;
_width = MaxHeight;
_height = MaxWidth;
break;
default:
madctl = ST77XX_MADCTL_MX | ST77XX_MADCTL_MY | ST77XX_MADCTL_RGB;
_width = MaxWidth;
break;
SendData(madctl);
private void SetDrawWindow(int x, int y, int width, int height)
y += _ystart;
x += _xstart;
buffer4[1] = (byte)x;
buffer4[3] = (byte)(x + width - 1);
SendCommand(ST7735CommandId.CASET);
SendData(buffer4);
buffer4[1] = (byte)y;
buffer4[3] = (byte)(y + height - 1);
SendCommand(ST7735CommandId.RASET);
SendData(buffer4);
private void SendDrawCommand()
SendCommand(ST7735CommandId.RAMWR);
public void DrawBuffer(byte[] buffer)
SendDrawCommand();
BitConverter.SwapEndianness(buffer, 2);
spi.Write(buffer);
public void DrawBuffer(byte[] buffer, int x, int y, int width, int height)
SetDrawWindow(x, y, width, height);
DrawBuffer(buffer, x, y, width, height, MaxWidth, 1, 1);
private void DrawBuffer(byte[] buffer, int x, int y, int width, int height, int originalWidth, int columnMultiplier, int rowMultiplier)
SendDrawCommand();
spi.Write(buffer, x, y, width, height, originalWidth, columnMultiplier, rowMultiplier);
#region Seesaw functions
private void WritePinMode(int pins, byte mode)
var data = new byte[] { (byte)(pins >> 24), (byte)(pins >> 16), (byte)(pins >> 8), (byte)pins };
var cmd = new byte[6];
Array.Copy(data, 0, cmd, 2, 4);
switch (mode)
case 1: //OUTPUT
cmd[0] = SEESAW_GPIO_BASE;
cmd[1] = SEESAW_GPIO_DIRSET_BULK;
_i2cDevice.Write(cmd);
break;
case 2: //INPUT
cmd[1] = SEESAW_GPIO_DIRCLR_BULK;
break;
case 3: //INPUT PULLUP
cmd[1] = SEESAW_GPIO_PULLENSET;
cmd[1] = SEESAW_GPIO_BULK_SET;
break;
case 4: //INPUT PULLDOWN
cmd[1] = SEESAW_GPIO_BULK_CLR;
break;
default:
break;
public void SetBacklightIntensityPercentage(double val)
if (val > 100)
val = 100;
if (val < 0)
val = 0;
var intensity = (ulong)(0xFFFF - (val / 100 * 0xFFFF));
_i2cDevice.Write(new byte[] { SEESAW_TIMER_BASE, SEESAW_TIMER_PWM, 0x0, (byte)(intensity >> 8), (byte)intensity });
void DigitalWrite(int pins, bool value)
if (value)
#endregion
Sample App:
namespace Sample
class Program
static void Main()
bool isBusy = false;
int wait = 0;
var i2cController = I2cController.FromName(GHIElectronics.TinyCLR.Pins.SC20100.I2cBus.I2c1);
var spi = SpiController.FromName(SC20100.SpiBus.Spi4);
var gpio = GpioController.GetDefault();
var min = new AdafruitMiniTFTWithJoystickFeatherwing(i2cController, spi, gpio.OpenPin(SC20100.GpioPin.PD3), gpio.OpenPin(SC20100.GpioPin.PD4));
// Create flush event
Graphics.OnFlushEvent += (s, data, x, y, width, height, originalWidth) =>
min.DrawBuffer(data);
min.Enable();
var screen = Graphics.FromImage(new Bitmap(min.Width, min.Height));
screen.Clear();
screen.Flush();
var font16 = Properties.Resources.GetFont(Properties.Resources.FontResources.Arial16);
var font23 = Properties.Resources.GetFont(Properties.Resources.FontResources.Arial23);
screen.FillRectangle(new SolidBrush(Color.FromArgb(128, 0, 0, 255)), 0, 0, 160, 80);
screen.FillRectangle(new SolidBrush(Color.FromArgb(128, 255, 0, 0)), 0, 0, 80, 80);
min.OnButtonStateChanged += (s, val) =>
isBusy = true;
screen.Clear();
screen.DrawString($"Button {s}", font23, new SolidBrush(Color.White), 0, 0);
screen.DrawString($"{val}", font16, new SolidBrush(Color.White), 0, 40);
screen.Flush();
wait = 5;
isBusy = false;
screen.DrawString("Welcome", font16, new SolidBrush(Color.White), 0, 40);
screen.Flush();
new Thread(() =>
if (!isBusy)
if (wait > 0) { wait--; }
screen.Clear();
var now = DateTime.Now;
screen.DrawString(now.ToString("MM/dd/yyyy"), font23, new SolidBrush(Color.White), 0, 0);
screen.DrawString(now.ToString("hh:mm:ss"), font16, new SolidBrush(Color.White), 0, 30);
screen.Flush();
Thread.Sleep(1000);
}).Start();
Thread.Sleep(-1);
