Hello,
i wish to use the Vbat pin on the tsc2046 controller on my chipworkx system, however when i attempt to use create my interface, i get a pin not available. i’m guessing that this has to do with the interface already being used by Spot.Touch. is there a workaround or a different method that one should use to read these pins?
my construction code (errors on s = new SPI(batconfig))
the error is
#### Exception System.Exception - CLR_E_PIN_UNAVAILABLE (1) ####
#### Message:
#### Microsoft.SPOT.Hardware.Port::.ctor [IP: 0000] ####
#### Microsoft.SPOT.Hardware.OutputPort::.ctor [IP: 0006] ####
#### Microsoft.SPOT.Hardware.SPI::.ctor [IP: 004d] ####
#### GUI_Test.Program::Main [IP: 01e7] ####
A first chance exception of type 'System.Exception' occurred in Microsoft.SPOT.Hardware.dll
SPI.Configuration Batconfig = new SPI.Configuration((Cpu.Pin)ChipworkX.Pin.PB22, false, 100, 10, false, false, 10, SPI.SPI_module.SPI1);
SPI s = new SPI(Batconfig);
i got PB22 from the schematic, this could also be the issue.
