baz
1
I need to access the SD card on Cerbuino, using 4.2.
I cannot find a simple and clear reference to this basic task!
May I use the Gadgeteer.Modules.GHIElectronics.SDCard? And the socket number required by the constructor?
Or may I use FEZCerbuinoBee.MountStorageDevice?
However my program when I try to run
Dim o1 = New GHIElectronics.Gadgeteer.FEZCerbuinoBee()
reports a runtime error
Mahhhhhhhhhhhhh
@ baz - There are a few posts that demonstrate this, but the search doesn’t always find what you want. Take a look at this post from Justin:
http://www.ghielectronics.com/community/forum/topic?id=8832&page=1#msg87858
The key here being that you need to use the GHI.OSHW.Hardware.StorageDev class.
-Valkyrie-MT
baz
3
Thank you.
Using this code, and some old one that I did run on Panda, I solved.
Thanks all – for both the question & answer… I’ve taken this as direction to add to the Cerbuino Bee’s Developers’ Guide (with Justin’s code from the referenced post http://www.ghielectronics.com/community/forum/topic?id=8832&page=1#msg87858)
baz
5
A Cerbuino Bee’s Developers’ Guide will be really important, thanks.
