Is the the 3.5" Display of Cobra OEM Box same as the “Display T35” of FEZ Spider Starter Kit?
I have only the “Display T35 Module”, does it pass the “Cobra” display connector?
I have built a board on the basis of Cobra board, and the display connector on the Cobra board is 40 pins. It seems that the IO17 is not used for display, but the pin IO17
is used in “Display T35 sch.pdf” as “SHDN#”.
Is “IO17” very import und necessary for the “Display T35 Module”?
