here is a new production from MBN, that will conciliate the power of the G400 SoM (using its TH model) and the ease of use of Mikrobus sockets.
Everything is pure NETMF and you will be able to use MikroElektronika’s Click boards as easily as with the Quail board since our Click boards’ drivers are standard NETMF C# drivers and are provided as (open)source code.
That looks great but I have an OT question on the fingerprint module.
I have one of those and I found that it was difficult to get a good reading if your finger is anything but 100% dry. Out here it’s damn hot all the time so my fingers tend for the most part to have a moist surface. You see this a lot with trying to use swipe type keyboards on phones and the movement is sticky from the damp finger.
I see this with my Samsung phone and it’s fingerprint reader. If my finger is even a little damp from sweat, it fails and a quick wipe to dry it off often works but with this reader I could not get it to work reliably.
It is a GT-511C3 Fingerprint Scanner by ADH-Tech. I found that pressure more than moisture affects the reliability. A finger placed with a slight firm pressure will give better results.
