Hi! Help me please. The client PC is not connected to the server on Cerberus. Server code:
sing System;
using System.Net;
using System.Net.Sockets;
using System.Text;
using Socket = System.Net.Sockets.Socket;
namespace GadgeteerApp4
public delegate void DataReceivedEventHandler(object sender, DataReceivedEventArgs e);
public class SocketServer
public const int DEFAULT_SERVER_PORT = 8080;
private Socket socket;
private int port;
public event DataReceivedEventHandler DataReceived;
public SocketServer()
: this(DEFAULT_SERVER_PORT)
public SocketServer(int port)
this.port = port;
socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
public void Start()
IPEndPoint localEndPoint = new IPEndPoint(IPAddress.Any, port);
Debug.Print(port.ToString());
socket.Bind(localEndPoint);
socket.Listen(Int32.MaxValue);
new Thread(StartServerInternal).Start();
private void StartServerInternal()
// Wait for a request from a client.
Socket clientSocket = socket.Accept();
// Process the client request.
var request = new ProcessClientRequest(this, clientSocket);
request.Process();
private void OnDataReceived(DataReceivedEventArgs e)
if (DataReceived != null)
DataReceived(this, e);
private class ProcessClientRequest
private Socket clientSocket;
private SocketServer socket;
public ProcessClientRequest(SocketServer socket, Socket clientSocket)
this.socket = socket;
this.clientSocket = clientSocket;
public void Process()
// Handle the request in a new thread.
new Thread(ProcessRequest).Start();
private void ProcessRequest()
const int c_microsecondsPerSecond = 1000000;
using (clientSocket)
try
if (clientSocket.Poll(5 * c_microsecondsPerSecond, SelectMode.SelectRead))
// If the butter is zero-lenght, the connection has been closed or terminated.
if (clientSocket.Available == 0)
break;
byte[] buffer = new byte[clientSocket.Available];
int bytesRead = clientSocket.Receive(buffer, clientSocket.Available, SocketFlags.None);
byte[] data = new byte[bytesRead];
buffer.CopyTo(data, 0);
DataReceivedEventArgs args = new DataReceivedEventArgs(clientSocket.LocalEndPoint, clientSocket.RemoteEndPoint, data);
socket.OnDataReceived(args);
if (args.ResponseData != null)
clientSocket.Send(args.ResponseData);
if (args.Close)
break;
catch (Exception)
break;
using System.Net;
public class DataReceivedEventArgs : EventArgs
public EndPoint LocalEndPoint { get; private set; }
public EndPoint RemoteEndPoint { get; private set; }
public byte[] Data { get; private set; }
public bool Close { get; set; }
public byte[] ResponseData { get; set; }
public DataReceivedEventArgs(EndPoint localEndPoint, EndPoint remoteEndPoint, byte[] data)
LocalEndPoint = localEndPoint;
RemoteEndPoint = remoteEndPoint;
if (data != null)
Data = new byte[data.Length];
data.CopyTo(Data, 0);
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
public partial class Program
ethernetENC28.NetworkUp += new GTM.Module.NetworkModule.NetworkEventHandler(ethernet_NetworkUp);
ethernetENC28.NetworkDown += new GTM.Module.NetworkModule.NetworkEventHandler(ethernet_NetworkDown);
ethernetENC28.UseDHCP();
SetupWindow();
Debug.Print("My IP is: " + ethernetENC28.NetworkSettings.IPAddress);
Debug.Print("My Sub is: " + ethernetENC28.NetworkSettings.SubnetMask);
private Text txtAddress;
private Text txtReceivedMessage;
private void SetupWindow()
Font MyFont = Resources.GetFont(Resources.FontResources.NinaB);
// displayN18.SimpleGraphics.DisplayText("Loading, please wait...",MyFont,GT.Color.Blue,0,0);
private void ethernet_NetworkDown(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print("Network Down!");
private void ethernet_NetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print("Network Up!");
txtAddress.TextContent = "IP Address: " + ethernetENC28.NetworkSettings.IPAddress + ", port 8080";
SocketServer server = new SocketServer(8080);
server.DataReceived += new DataReceivedEventHandler(server_DataReceived);
server.Start();
private void server_DataReceived(object sender, DataReceivedEventArgs e)
string receivedMessage = BytesToString(e.Data);
txtReceivedMessage.Dispatcher.BeginInvoke(
delegate(object arg) {
txtReceivedMessage.TextContent = "Received message: " + arg.ToString();
return null;
receivedMessage);
string response = "Response from server for the request '" + receivedMessage + "'";
e.ResponseData = System.Text.Encoding.UTF8.GetBytes(response);
if (receivedMessage == "close")
e.Close = true;
private string BytesToString(byte[] bytes)
string str = string.Empty;
for (int i = 0; i < bytes.Length; ++i)
str += (char)bytes[i];
return str;
PC client code:
sing System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Net;
using System.Text;
namespace ClientMSDN
class Program
static void Main(string[] args)
// Data buffer for incoming data.
byte[] bytes = new byte[1024];
// Connect to a remote device.
try
// Establish the remote endpoint for the socket.
// This example uses port 8080 on the local computer.
IPHostEntry ipHostInfo = Dns.Resolve(Dns.GetHostName());
IPAddress ipAddress = ipHostInfo.AddressList[0];
IPAddress ip = IPAddress.Parse("192.168.100.11"); //Плата
// IPAddress ip = IPAddress.Parse("192.168.0.103"); // ПК
IPEndPoint remoteEP = new IPEndPoint(ip, 8080);
// Create a TCP/IP socket.
Socket sender = new Socket(AddressFamily.InterNetwork,SocketType.Stream, ProtocolType.Tcp);
try
sender.Connect(remoteEP);
Console.WriteLine("Socket connected to {0}",
sender.RemoteEndPoint.ToString());
// Encode the data string into a byte array.
byte[] msg = Encoding.ASCII.GetBytes("This is a test<EOF>");
// Send the data through the socket.
int bytesSent = sender.Send(msg);
// Receive the response from the remote device.
int bytesRec = sender.Receive(bytes);
Console.WriteLine("Echoed test = {0}",
Encoding.ASCII.GetString(bytes, 0, bytesRec));
// Release the socket.
sender.Shutdown(SocketShutdown.Both);
sender.Close();
catch (ArgumentNullException ane)
Console.WriteLine("ArgumentNullException : {0}", ane.ToString());
catch (SocketException se)
Console.WriteLine("SocketException : {0}", se.ToString());
catch (Exception e)
Console.WriteLine("Unexpected exception : {0}", e.ToString());
catch (Exception e)
Console.WriteLine(e.ToString());
When you run the client simply connects to the server. The server does not ping from the command line.
“System.Net.WebException: Unable to connect to the remote server —> System.Net. Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection fail ed because”
Antivirus and firewall are disabled.
