Don’t let anyone tell you you can’t have too many LED’s
I found a few more cables…
Video shows (bit rough) that each LED output has 256 levels of brightness.
Looks great!
@ Architect - Thanks.
Now I just need to convince every Gadgeteer user they would be lost without one in their toolbox
That looks great! I guess it’s time to place another order!
Got that store up yet?
You must be having a laugh…
It’s getting closer to the top of the todo list…honest… ![]()
Make them red and you either have KITT or the Centurion Cylon.
lol
How many can be chained together? How much? Are they for sale yet?
@ ianlee74 -
- Chain s many as you want…
- $11.95 without headers $14.95 with headers soldered on
- I have a few ready…
I suppose i should also mention that each bank of 18 outputs can be set to 10ma or 20ma max current via pin headers.
Buy a few and the price goes down…
That idea has been suggested by someone else today ![]()
It would be really cool if external power could be applied. Then you’d have a one-stop LED cube module. This would still need to be used in conjunction with transistors to power an LED array ![]()
I see a white connector there. I assume it is to connect an external power source.
Yes, but is that supplying the LED directly or the chips? It sounds like there may be a 20mA limit coming from the chip for each pin. So, for an LED cube you would be limited to only lighting one LED per pin at a time. It appears to be fast enough for that to work fine but you lose intensity.
@ ianlee74 - white connector is just for the LEDs, ic’s are powered off the socket.
Each output can sink up to 30ma but I have chosen 20 and 10ma each.
Can change resistors to 30ma if needed.
So you can draw 54 x 20ma per driver at once to keep the room warm
Just light them all up at once…
Juzzy, can you add your modules to http://wiki.tinyclr.com/index.php?title=Community_Offers when you get a chance? I can’t keep track of them all ![]()
Yes, please. Particularly until you get that website done. ![]()
I’m not ordering anything else from Justin (aka Juzzy) until he either gets his store up or lists the items on the community offers page.
Fellas, can I get a +1???
(just kiddin…)
Yeah !!
I only ask so I can figure out how much money I need to set aside for gadget funds this month
@ Brett - add a few more $$'s as I have a few more ready
Yes the site is coming…
Also about to start plotting with SteveP to get him to cover the other side of the big ditch.
