So how long before you guys make a FEZ version of this
I am shocked that they give the skiz on it.
I am the fortunate owner of such device. It works well.
However, the graphical interface is a huge pain to use and get used too.
Got mine from seeedstudio.
The hardware and software are opensource so you can improve it
Also they come not calibrated, and the process to do so takes times. And everytime you upgrade the software, you loose you calibrationsâŚ
More data here : http://www.seeedstudio.com/wiki/index.php?title=DSO_Quad
Iâve been eyeing one of those as a potential bâday present request What is required in the calibration process? If I donât already have a bench scope is it going to be impossible to calibrate this one? Would this meet most hobbyist needs or should I go ahead and spring for a bench or PC model?
There is 2 sort of calibration:
Both processes are explained in the documentation:
http://www.seeedstudio.com/forum/download/file.php?id=671
A friend just got me DSO Nano v2 for bday. Neat little device!
By the way, just seen on this ebay page âproviding 72Mhz analog bandwidthâ.
It is false. It is a 72MS/s ADC , that a big difference ! You can expect about 10Mhz bandwith.
Would this be useful in reverse-engineering an IR protocol?
Better use a specialized toy, for 10 times less !
http://www.seeedstudio.com/depot/usb-infrared-toy-v2-p-831.html?cPath=174
or a real logic analyser:
http://www.seeedstudio.com/depot/open-workbench-logic-sniffer-p-612.html?cPath=174
As you can see in the link:
[url]http://www.seeedstudio.com/wiki/index.php?title=DSO_Nano_v2[/url]
Itâs capable of only
[quote]
Analog bandwidth 0 - 200KHz
Max sample rate 1Msps 12Bits [/quote]
Now I see this topic is about the âquadâ.
[quote]or a real logic analyser:
[/quote]
I have actually used SUMP the last week. Ran the logic analyser part on my Sparten3 dev board. It worked OK. I debugged what I needed to debug. But the software can do with a rework.
Zooming in is a pain as the data moves during zoom.
Triggers donât work when set to 256K buffer.
But it worked.
Might be worth while to write a client in C# for the boardâŚ
Not likely to use SUMP myself. I donât have anything else that uses Java, and not particularly interested in installing (and having to keep updating) a JVM just for one application. Of course, in fairness, I probably have a slight bias towards .NET, given who I work for.
The short-term cheap solution for me is to just capture the data with the IR receiver, and copy the buffered uint values into Excel. I can write a formula to convert the high values to 1 and the low values to 0, then analyze from there. Itâs more work that way, but it wonât require me to buy any new equipment.
If you already have an iPad, this looks like a cool offering.
