ianlee74,
here’s my multisensor class running on my Cobra, hope it helps:
using System.Collections;
using CobraController.Objects;
namespace CobraController
class OWSensors
#region Enums
const string DS18S20 = "DS18S20";
const string DS18B20 = "DS18B20";
const string DS1822 = "DS1822";
const string DS2438 = "DS2438";
const string Temp = "Temp";
const string Light = "Light";
const string Hum = "Hum";
enum Model
DS18S20 = 0x10,
DS18B20 = 0x28,
DS1822 = 0x22,
DS2438 = 0x26
enum Command
SearchROM = 0xF0,
ReadROM = 0x33,
MatchROM = 0x55,
SkipROM = 0xCC,
AlarmSearch = 0xEC,
StartTemperatureConversion = 0x44,
StartVoltageConversion = 0xB4,
ReadScratchPad = 0xBE,
WriteScratchPad = 0x4E,
CopySratchPad = 0x48,
RecallEEPROM = 0xB8,
ReadPowerSupply = 0xB4,
ScratchPadPage0 = 0x00,
ScratchPadPage3 = 0x03
enum ScratchPadDS2438
CONFIGURATION = 0,
TEMP_LSB = 1,
TEMP_MSB = 2,
VOLTAGE_LSB = 3,
VOLTAGE_MSB = 4,
CURRENT_LSB = 5,
CURRENT_MSB = 6,
THRESHOLD = 7,
SCRATCHPAD_CRC = 8
enum SPDS2438
CONFIGURATION,
TEMP_LSB,
TEMP_MSB,
VOLTAGE_LSB,
VOLTAGE_MSB,
CURRENT_LSB,
CURRENT_MSB,
THRESHOLD,
SCRATCHPAD_CRC
#endregion
static OneWire ow;
static double temptemp;
public OWSensors(FEZ_Pin.Digital pin)
ow = new OneWire((Cpu.Pin)pin);
public void GetSensorValues()
lock (SensorCollection.GetInstance)
SensorCollection.GetInstance.Collection.Clear();
int OW_number = 0;
byte[] OW_address = new byte[8];
string SensAddress;
string NewSensAddress;
string SensModel;
string SensType;
if (ow.Reset())
while (ow.Search_GetNextDevice(OW_address))
OW_number++;
SensAddress = GetSensorAddress(OW_address);
SensModel = GetSensorModel(OW_address);
SensType = GetSensorType(OW_address);
if (SensModel == DS2438)
SensorData sd = new SensorData();
NewSensAddress = SensAddress + ":T";
sd.sensorAddress = SensAddress + ":T";
sd.sensorModel = SensModel;
sd.sensorType = Temp;
sd.sensorValue = GetTemperatureC(OW_address);
temptemp = sd.sensorValue;
SensorCollection.GetInstance.Collection.Add(sd);
if (MultiSensor(OW_address))
sd.sensorType = SensType;
if (sd.sensorType == Hum) sd.sensorValue = GetHumidity(OW_address, temptemp);
if (sd.sensorType == Light) sd.sensorValue = GetLightLevel(OW_address);
//NewSensAddress = SensAddress;
NewSensAddress = SensAddress + ":H";
sd.sensorAddress = SensAddress + ":H";
NewSensAddress = SensAddress + ":L";
sd.sensorAddress = SensAddress + ":L";
//Debug.Print("Model:" + SensModel + " Type:" + SensType + " Address:" + NewSensAddress );
//Debug.Print("Sensors found: " + SensorCollection.GetInstance.Collection.Count);
private string GetSensorAddress(byte[] ow_address)
int i;
string address = string.Empty;
for (i = 0; i < 8; i++)
address += Helpers.FromByteToHex(ow_address[i]);
if (i < 7)
address += ":";
return address;
private string GetSensorModel(byte[] ow_address)
switch ((ow_address[0]))
case (byte)Model.DS18B20:
return DS18B20;
case (byte)Model.DS2438:
return DS2438;
case (byte)Model.DS18S20:
return DS18S20;
case (byte)Model.DS1822:
return DS1822;
default:
return "unknown";
private bool MultiSensor(byte[] ow_address)
byte[] model = new byte[1];
ow.Reset();
ow.WriteByte((byte)Command.MatchROM);
ow.Write(ow_address, 0, ow_address.Length);
ow.WriteByte((byte)Command.ReadScratchPad);
ow.WriteByte((byte)Command.ScratchPadPage3);
ow.Read(model, 0, 1);
return model[0] > 0 ? true : false;
private string GetSensorType(byte[] ow_address)
ow.Reset();
switch (model[0])
case 25:
return Hum;
case 27:
return Light;
default:
return "na";
private float GetTemperatureC(byte[] ow_address)
float TemperatureC = 0;
byte[] scratchpad = new byte[9];
ushort tempLow = 0;
ushort tempHigh = 0;
byte countremain = 0;
byte countc = 0;
ushort temp = 0x0;
float result = 0f;
bool negative = false;
int temptemp;
short t = 0;
switch (ow_address[0])
ow.Reset();
ow.WriteByte((byte)Command.StartTemperatureConversion);
while (ow.ReadByte() == 0) { }
ow.Reset();
ow.Read(scratchpad, 0, 9);
tempLow = scratchpad[0];
tempHigh = scratchpad[1];
countremain = scratchpad[6];
countc = scratchpad[7];
Int16 rawTemperature = (Int16)((tempHigh << 8) | tempLow);
TemperatureC = (float)(rawTemperature >> 1) - 0.25f + ((float)(countc - countremain) / (float)countc);
break;
ow.Reset();
ow.Reset();
byte config = scratchpad[4];
bool crc = OneWire.CalculateCRC(scratchpad, 0, 8) == scratchpad[8];
temp = tempLow;
temp |= (ushort)(tempHigh << 8);
temptemp = (((int)(tempHigh) << 8) | tempLow);
TemperatureC = temptemp * 0.0625f;
break;
ow.Reset();
ow.Reset();
ow.WriteByte((byte)Command.RecallEEPROM);
ow.WriteByte((byte)Command.ScratchPadPage0);
ow.Reset();
tempLow = scratchpad[1];
tempHigh = scratchpad[2];
// temperature is negative if sign bit set
negative = ((tempHigh & 0x80) == 0) ? false : true;
// construct complete temp value
t = (short)((tempHigh << 8) + tempLow);
// if negative, take two's complement to get absolute value
if (negative)
t = (short)-t;
// get integer part if any
result = (float)(t >> 8);
// remove zero bits and add fractional part if any
result += ((t >> 3) & 0x1f) * 0.03125f;
// return value with correct sign
TemperatureC = (negative) ? -result : result;
break;
default:
break;
return TemperatureC;
private float GetHumidity(byte[] ow_address, double temp)
ow.Reset();
ow.WriteByte((byte)Command.WriteScratchPad);
ow.WriteByte((byte)0x0);
//while (ow.ReadByte() == 0) { }
Thread.Sleep(10);
ow.Reset();
ow.Reset();
ow.WriteByte((byte)Command.StartVoltageConversion);
//Thread.Sleep(10);
ow.Reset();
short t;
float result;
t = (short)((scratchpad[4] << 8) | scratchpad[3]);
result = (float)(((t * 0.01f) - 0.958) / 0.0307f);
result = (float)result / (1.0546f - (0.00216f * (float)temp));
return result;
private float GetLightLevel(byte[] ow_address)
ow.Reset();
Thread.Sleep(10);
ow.Reset();
//Thread.Sleep(10);
ow.Reset();
short t;
float result;
result = (float)((t / 100f) / 5.0f) * 100.0f;
return result;
