Hello,
i want to controll my LED-Cube, with the FEZ Panda II.
The LED-Cube should start when the infrared photocell is broke through.
The LED-Cube is working without the infrared photocell but with it it doestn work.
Here is my C# source code:
namespace FEZ_Panda_II_Application1
        InputPort In1 = new InputPort((Cpu.Pin)FEZ_Pin.Digital.Di0, true, Port.ResistorMode.PullUp);
        OutputPort layer_1 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di26, false);
        OutputPort layer_2 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di28, false);
        OutputPort layer_3 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di35, false);
        OutputPort layer_4 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di36, false);
        //Led 1-9
        OutputPort pin_1 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di20, false);
        OutputPort pin_2 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di22, false);
        OutputPort pin_3 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di24, false);
        OutputPort pin_4 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di30, false);
        OutputPort pin_5 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di32, false);
        OutputPort pin_6 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di34, false);
        OutputPort pin_7 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di38, false);
        OutputPort pin_8 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di40, false);
        OutputPort pin_9 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di42, false);
            if (In1.Read() == false)
                layer_1.Write(false);
                layer_2.Write(true);
                layer_3.Write(true);
                layer_4.Write(true);
                pin_1.Write(!pin_1.Read());
                Thread.Sleep(150);
                pin_2.Write(!pin_2.Read());
                Thread.Sleep(150);
                pin_3.Write(!pin_3.Read());
                Thread.Sleep(150);
                pin_6.Write(!pin_6.Read());
                Thread.Sleep(150);
                pin_5.Write(!pin_5.Read());
                Thread.Sleep(150);
                pin_4.Write(!pin_4.Read());
                Thread.Sleep(150);
                pin_7.Write(!pin_7.Read());
                Thread.Sleep(150);
                pin_8.Write(!pin_8.Read());
                Thread.Sleep(150);
                pin_9.Write(!pin_9.Read());
                Thread.Sleep(150);
                layer_1.Write(true);
                layer_2.Write(false);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                layer_3.Write(false);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                layer_4.Write(false);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
                Thread.Sleep(150);
