[quote]Speaking at the company’s “Make It Wearable challenge” in San Francisco, Brian Krzanich, the company’s CEO, stated that “We’ll have a better Edison in 2015 that will be smaller,” before adding “I still have the vision that we can take all of the functionality we have on Edison today and put it in something that’s roughly the size of your coat button”.
The new Edison, Krzanich reckons, will run on a battery about the same size for a couple of days, which means, he continued, that you will be able to run a computer in your coat button.
Now a coat button (not a shirt button) is about the size of a 3V CR2016 battery, a 20mm model that’s 1.5mm thick and has a typical capacity of 90mAh. The current Edison PC was originally supposed to be the size of a SD card but ended up being a tad bigger…
Krzanich also revealed that Intel is working on two different ways of improving battery life on wearable devices, with devices based on these coming out in 2015. He stated “You can have an analogue part that’s always listening and always sensing, that’s very low power. Then if it sees something, whatever your sensor is monitoring, then this turns the digital side on.”[/quote]
