This is not really a GHI topic but I suppose it very interesting for all the hardware freaks here.
I wrote an open-source 17 channel Logic Analyzer for the Parallel (Printer) Port.
Features:
* Digital Oscilloscope / Logic Analyzer with up to 17 input lines
* Uses the parallel (printer) port for input.
* While Logic Analyzers normally are very expensive, this one is for zero cost
* Written in speed optimized C++ to get the maximum possible sample rates
* The program is a stand alone single EXE file which neither needs any additional DLLs nor any framework. It runs out of the box
* Runs on all Windows platforms (95, 98, ME, NT, 2000, XP, 2003, Vista, 2008, Windows 7, 2008 R2)
* Runs on 32 Bit Windows and 64 Bit Windows
* When first run, installs a driver to access hardware IO ports on all NT platforms
* Plays a sound via PC speaker to prove that the driver works correctly
* Shows the actual state of the input lines life in the LED's of the GUI
* Captures up to 500.000 samples / second (depending on your hardware and OS)
* Captures to memory (rather than disk) for maximum speed
* Capturing runs always with the maximum frequency that the hardware allows
* Memory saving capture technology stores only the changes of the input lines rather than storing all lines with each sample that is taken
* The capture process is independent of data analyzing so you can try various settings to display the captured data in the best way
* The analyzer generates coloured oscilloscope diagrams with a raster grid
* The output is written into an HTML file and one or multiple GIF files
* So the analyzer results can easily be shared with other people who must not install any program to view a proprietary binary format
* You can write an individual heading into each analyzer output to distinguish them later in a multitude of files
* When analyzing data, you can choose to delete old analyzer output or keep the old files
* The time axis shows absolute or relative time with microsecond precision (Performance Counter)
* Automatic detection of inactive input lines shows only the channels that have activity
* Automatic detection of idle time cuts out long phases of inactivity
* Automatic detection of input frequency chooses the adequate raster unit like on a real oscilloscope (10 µs, 20 µs, 25 µs, 50 µs, 100 µs, etc..)
* Automatic detection of context switches of the operating system
* Decoded serial data (Start Bit, Parity, Acknowledge, Stop Bit) and the Byte that they represent may be printed into the diagrams and/or printed to HTML where it can be copied to the clipboard.
* Decoded serial data (Start Bit, Parity, Acknowledge, Stop Bit) and the Byte that they represent is written into the diagram
* Very cleanly written source code with a proper error handling and plenty of comments
http://www.codeproject.com/Articles/75279/17-Channel-Logic-Analyzer
Elmü
