using the ELN-60-48P according to what i’ve read online and what the specs says, i need 10V on PWM but for what i have read also Panda PWN are just 5V.
Correct me if i’m wrong (as i say not an electronic guy) but if i run the driver on 5V PWM signal i will not get complete full power, right?
Panda PWM pins (in fact all output pins) are only 3V3, not 5V. You need to drive the PWM pin that then drives something like a transistor as C0ax points out, and have that drive the 10V.
well i just got confused…So i cant connect directly my drivers?
they need a 5V PWM signal…Do i need to add some component? I ask because several people have confirmed that they use that driver directly connected to an arduino PWM pin
I havent tested this of course and i’m a complete newbie, so please clear my confusion.
