anyone already tried 1-Wire with preview4?
wonder why the 1-Wire sample app does not find a sensor Number of sensors found = 0
Did it work on preview3?
i dont know, i started with preview 4 to play with
I hate one wire! Useless and always a problem. Can we please get rid of it?!!!
Who uses it anyway?
Is it a DS18B20-PAR or a DS1820B. If it is the parasitic version of the sensor it may not work. Parasitic 1-Wire devices did not work in NetMF and may not work in TinyCLR.
Just double checked, one wire works perfectly on P4. Check your connection.
its easy to use (if it works) and cheap and some awesome easy to use temperature sensors with long cables are available, and not to forget the power supply
thank you for your trial, now i know its may be a layer 8 problem
thank you, i have no idea but good to know, fortunately they are not expensive
If I’m not mistaken it’s quite a popular thing in pick and place machines to address feeders…
Also, those ibuttons. Altough those only implement the bare minimum of one wire.
But yes, there’s always problem with it.
I am testing DS18B20 with FEZ Stick but not found devices with sample code… the probe works fine with NetMF in Netduino board… Can I use any pin in FEZ Stick to use 1-Wire?
FEZ stick supports onewire, meaning you can use any pin.
I know my own C# class works perfectly with the FEZ Duino - I suspect they’re using the same framework.
