I ran into another issue today… The framework seems unable to to convert an Enum type to a string. I tried several variations, including:
var output = value.ToString();
compressorState = value;
var output = compressorState.ToString();
var output = ((CState)compressorState).ToString();
All threw the same error seen in the screenshot.
That’s a deliberate known issue (sixth paragraph) in the current and previous two releases. The workaround is to cast to an int (or whatever the underlying type is).
var output = ((int)compressorState).ToString();
ToString
never supported returning the name of the enum member as a string as it should anyway, so casting to an int
doesn’t currently lose any functionality.
