FEZ Starship.
Or FEZ EB (Entreprise Board)
FEZ Nexus
Nexus (noun) - A connection or series of connections linking two or more things.
I like FEZ Nexus.
But as one mentioned prior about maintaining the Myth line of naming, maybe FEZ Yggdrasil (pronounced ig dra sil?) which is the Norse myth of the tree that connects the Nine worlds: Yggdrasil - Wikipedia
Fez Matrix
@ Aron - a âsounds likeâ then i hope or we will not be able to order these on the phone
Hmmm, maybe a little bit to much⊠connecting the nine worlds.
What about a bridge ?
FEZ bifrost
(Bifröst : From Wikipedia, the free encyclopedia
In Norse mythology, Bifröst (Bifrost in Scandinavia) or sometimes Bilröst, is a burning rainbow bridge that reaches between Midgard (the world) and Asgard, the realm of the gods )
Midgard (the world) : Gadgeteer
Asgard, the realm of the gods ) : PC
FEX Collective
âWe Are FEZâ
Resistance is futile, you shall be assimilated. lol
I like a simple âFez Gadgteteer Linkâ. Tells what it does - it links us to Gadgeteer modules.
FEZ Symbiote
FEZ CGI (Connected Gus Interface ⊠uhm I mean Connected Gadgeteer Interface)
Gadgeteer Gorgon
FEZ Medusa
Iâm picturing a bunch of modules radiating from this yet-unnamed board resembling Medusaâs head. And itâs mythical.
Fez Overboard
FEZ Prometheus
A promising idea.
Will these wrappers be source-code compatible with NETMF, so that you can move code back and forth between a PC and a true mainboard, without having to modify it (as long as you donât use features that are only available in the full .NET framework, of course)?
Will the serialization protocol over USB be open and documented, so that, for example, a compatible library could be built for Mono on a Raspberry Pi?
Cuno
@ Cuno - Linux and Android support come standard, even Mac.
I like the previous suggestion of FEZ Link.
FEZ_Command
Whatever name you give it⊠A GREAT idea!
FEZ Burner
FEZ Crosser
FEZ Wire
Raspberry Smoothie
