New PC and Protection software so it may be me.
I have to login ever time I come here.
Thanks in advance.
Thanks in advance.
Do you have your cookies turned off?
@ ianlee74 -
I have always used the default setting of the browser I am using. (Most always IE or Firefox)
I asked because along time ago GHI had to reset something.
Like I said I am using a new PC with the latest Kaspersky.
I have just upgraded to Windows 10 Pro so maybe it has something to do with that because no login problem before that.
@ andre.m -
As far as I can tell it should be working but I’m not a expert on browsers.
Firefox does the same thing.
After log on I have checked for a GHI Cookie. It was there.
I shut down my PC and restarted.
I again checked for the GHI Cookie and it was in the INetCache.
Go to https://www.ghielectronics.com and I still have to logon again.
See images of IE settings.
Firefox > Options > Privacy > remove individual cookies
If you search for ghielectronics do you see GHICookie? Click on it and what info does it show?
@ Josh -
I am not sure if this is what you want.
Found in:
C:\Users\willg\AppData\Local\Microsoft\Windows\INetCache
FIle text QKJ75JJM.txt content below
_ga
GA1.2.1045093065.1441280983
1088
393341312
30614553
645686443
30467702
_gat
1
1088
2120758912
30467703
425614067
30467702
GHICookie_RID
434128
9217
1741884800
30473700
1828039419
30467665
Thanks for your reply. It is driving me crazy!
I never change my browser settings so I really do not know what I am doing…
There are several cookies with GHI some say not available if clicked on.
Sorry! You were asking about Firefox and I gave you IE cookie
Images for Firefox attached
Update
Somehow I got Firefox to work. Not sure what I changed to get it working,
I will see if it still works tomorrow.
IE and Microsoft Edge still not working. (They did before)
you’re not using in-private browsing are you ?
In Edge, go into Settings, Advanced Settings, and check the setting here
@ Brett -
Yes I have that setting for cookies.
I did something and now I can log on using Edge. I put the GHI link on the Start Page (Windows Button).
(However I forgot how I did that) Hard gettin’ old!
IE still requires a Log On every time
I now have IE working and can join the GHI form without having to log on each time.
Easy fix… I Reset Internet Explorer settings and BINGO!
(States that ‘You should only use this if your browser is in an unstable state’)
I still have no idea why installing the Windows 10 Pro update messed up the browsers (Setting I had).
Everything worked fine before the upgrade from Windows 10 to Windows 10 Pro.
We’re just glad you don’t have to type as much now.
