-1000 experience points!
lol
Writing is now working fine, thank you all.
Only thing left is reading. I cannot get a working way of how to transform from a memory reader to a actual sd reader.
This is what I have so far, Is this correct, what to change to make it work? Note the comment on where I do not know what to do.
public void ReadXml(string XmlFile)
// SD Card is inserted
// Create a new storage device
PersistentStorage sdPS = new PersistentStorage("SD");
// Mount the file system
sdPS.MountFileSystem();
// Assume one storage device is available, acces it through
// Micro Framework and display available files and folders:
// Debug.Print("Getting files and folders: ");
try
FileStream
FileHandle = new FileStream(rootDirectory + @ "\" + XmlFile + ".xml",
FileMode.Open, FileAccess.Read);
byte[] data = null; //what to do?
char[] cc = System.Text.UTF8Encoding.UTF8.GetChars(data);
string str = new string(cc);
Debug.Print(str);
MemoryStream rms = new MemoryStream(data);
XmlReaderSettings ss = new XmlReaderSettings();
ss.IgnoreWhitespace = true;
ss.IgnoreComments = false;
XmlReader xmlr = XmlReader.Create(rms, ss);
while (!xmlr.EOF)
xmlr.Read();
switch (xmlr.NodeType)
case XmlNodeType.Element:
Debug.Print("element: " + xmlr.Name);
break;
case XmlNodeType.Text:
Debug.Print("text: " + xmlr.Value);
break;
case XmlNodeType.XmlDeclaration:
Debug.Print("decl: " + xmlr.Name + ", " + xmlr.Value);
break;
case XmlNodeType.Comment:
Debug.Print("comment " + xmlr.Value);
break;
case XmlNodeType.EndElement:
Debug.Print("end element");
break;
case XmlNodeType.Whitespace:
Debug.Print("white space");
break;
case XmlNodeType.None:
Debug.Print("none");
break;
default:
Debug.Print(xmlr.NodeType.ToString());
break;
sdPS.UnmountFileSystem();
sdPS.Dispose();
catch(Exception e)
Debug.Print("exception: " + e.ToString());
I think I might overlook some stupid mistake again. Have tried several things, so I just added a “null” to it. Hope you can help me
Thanks again!
See what methods are in the FileStream class. One of them is a read function, IIRC.
Tried that one before, then the program hang, the lcd went black and the emx chip was heating, lol.
Will try it again later on, thanks
YES!! I finally got it to work!
I wrote this to a XML file on the SD in the program.cs:
write.WriteXml("XML1", "Foekie", "On");]
Then I read the xml file using the xml reader in the xml read class:
And it returned:
<?xml version="1.0" encoding="utf-8"?>
<FEZProto_UserData>
<UserName>Foekie</UserName>
<Sound>On</Sound>
</FEZProto_UserData>
decl: xml,
comment All the user data will be stored in this file.
element: FEZProto_UserData
element: UserName
text: Foekie
end element
element: Sound
text: On
end element
end element
none
@ Chris: this is the working solution to reading the file:
byte[] data = new byte[FileHandle.Length];
FileHandle.Read(data, 0, data.Length);
Thank ALL of you! You have been a great help for me!
