I’m looking for wireless sensor communication. The XBee seems to be solution. So, if I understand correctly, I need XBee Adapter Module to connect in socket U on Gadgeteer and same Adapter module for each sensor. So any digital or analog sensor could be connected to this XBee module?
There are AD pins on the board.
Yes, I saw this. But it’s looking scary simple, so i thought that there must be some catch.
So : one XBee module on spider, one for each sensor, and sensor connects to AD pins?
The sensors would be connected just to XBee module, without FEZ spider mainboard?
http://fab.cba.mit.edu/classes/MIT/863.10/people/jie.qi/xbee_tut.html
http://www.kobakant.at/DIY/?tag=xbee
And searching “I/O Line Passing” in Google.
@ Tzu Hsuan - Thanks
Also found synapse wireless modules. Has anyone experience with this? From their site i don’t understand which module I must order for connecting fez spider and digital sensor.
Hi, andre.m
Do you make the synapse gadgeteer module?
What is the benefit for this module than using Xbee?
Thanks.
I think that benefit is range, security an reability
Andre, i would like to order this modules and study it at home, but there are several option, and i dont know which of these do i need. Could you please just tell me what i need: i would like to have some digital sensor, maybe moving detector, that i could read remotly with my fez spider. So which of this modules i need for spider, and which for sensor. For now, the range is not a issue, becouse it’s for educative purpose.
Thanks.
@ andre.m - thanks for explanation. This seems to be perfect solution.
Are there any distributors in EU for Synapse?
