As soon as I power up the Cerb 40 II the surface temperature of the chip immediately goes to around 65⁰ C, which is near the limit of the listed operating range. In comparison the Cerberus board only gets to 24⁰ C when under load.
The Cerb40II will still accept firmware and I can run some code on it but I’m concerned that it’s headed for imminent failure. Does this mean that I’ve toasted the Cerb40II?
You may be due an RMA if the board is defective. Has it ever been attached to anything or is it like this from the beginning? You may want to post some high-res photos of the board for GHI to verify the assembly looks correct.
If it’s heating up like that it could be there is a pin that is shorted somewhere (i.e. something drawing to much current). Check the voltage across the power. Also, does the chip actually work at those temps?
Chip seems to actually works when at the high temp. All I’ve tested was to flash the firmware and made a couple of LEDs blink.
Thanks for all of the responses but I’m guessing that even though it’s working that it won’t work for long. I’d also assume that it was a misstep on my part that was the cause so I won’t be asking for an RMA. I’ll give up on this and use it for solder training.
