@ Pete, if you would rotate IC2 togetter with R2 90 degrees clockwise, you could get rid of that weird angle there. Plus, if you swap RX and TX on that custom 4 pin connector, you could get rid of that one trace on solder side. Then move the connector slightly to R3 and your traces will have the room they need.
These are just suggestions, as I still believe PCB design is an art in itself
Thanks, Iāll try that out and see how things fit. Now that youāve mentioned it, I see I can really shorten some of those traces by doing that. Thanks!
I suspect if I swap +5V and ground on the pin headers on the right, Iāll be able to do some similar shortening of traces as well.
Very nice. One small thing, the IC1 label is on top of R3.
sorry for giving you all that extra work! But this small PCB might be the reason to get me started with Gadgeteer!
can I preorder one?
Thanks. I redid the whole outline for the MIDI jacks as I didnāt care for the adafruit ones (and the SparkFun ones have bad schematic pinouts). Once I did that, I was able to fit the label in where itāll be barely visible. I didnāt want any silk screening on the back as mose fab houses charge a bunch more for that.
@ All
Ok, second issue, though: It seems like Iām stuck with vector fonts. I donāt understand why. I designed with proportional fonts, but when I look at the output from the Seeed CAM processor for Eagle, the fonts are all vector and completely screwed up. I tried with 3 different gerber viewers.
I wanted to try the ITead CAM processor (they actually do black silkscreening on prototype boards so I really wanted to use them), but their CAM processor crashes Eagle every single time. Like hard ghosted app crash. I donāt know where to start looking for issues there.
Any idea what I need to look for to get this font issue fixed? Iām pretty sure Seeed will do proportional fonts. The vector font stuff is capital U Ugly. Or do I just need to bite the bullet and do this as vector?
I would hate tossing out 10 just to see if one works.
For smaller quantity (and cool purple color) I have use Temple of the Demented Diode before http://dementeddiode.org/blog/
Good quality. Downside is waiting for a board to fill up for a run.
I sligtly remember needed to do something in eagle to get vector fonts to work right. Vectors are good, not bad. Only way to scale a font to right size you need. Maybe it was just a display thing or a switch. I canāt remember.
@ Pete I sent you an email to discuss the possibility of turning this into a production module. We love MIDI but there is no MIDI expert like Pete in this community. I have seen a picture of your lab
It took a couple reads to find that in the module builderās guide.
āThe low logic input is 0V minimum, 0.4V maximum. Logic input high is 0.7*Vdd min, Vdd+0.2 maximum.ā
With VDD presumably at 3.3v, that would give you 3.5v. +0.1v headroom gives you this:
āAll pins must be at least 3.6V tolerant.ā
Looks like Iāll need to find a way to drop that voltage to make it compliant. One possibility is seeing how well that 6n138 works at 3.3v vs 5v. Looks like Iāll have to cut a trace on one of my prototypes when they arrive
Right, that was my suggestion. However, Iāll need to see how well the opto runs off 3.3v. Many devices like that take a huge perf hit when you lower the voltage. Some of my other optoisolators wouldnāt work at all at 3.3v. Iāll need to test for sure
