In ComputeTextInRect the documentation speaks of dtFlags, which flags would these be as I’m looking for wordwrap and it doesn’t appear to be Bitmap.DT_WordWrap as that doesnt seem to give me the answer Im looking for (ie the x component doesn`t seem to be wrapping).
[MethodImplAttribute]
public void ComputeTextInRect (
string text,
ref int renderWidth,
ref int renderHeight,
int xRelStart,
int yRelStart,
int availableWidth,
int availableHeight,
UInt32 dtFlags
These are the const UInt32 fields that start with DT_ (defined inside Bitmap class).
For example Bitmap.DT_WordWrap
I was afraid of that as that is what I’ve tried and it didn’t work Of course test code provided as maybe I’m doing something wrong, Fez Spider with a button and a OLEDisplay. The X component counts up nicely till it hits the max length 128 and when the display wraps but X remains as 128 which is the problem as it should go to 0 or some other number inidicating its over to the left.
using GT = Gadgeteer;
namespace TestWrap
public partial class Program
GT.Timer _timer = new GT.Timer(500);
private string _test = "";
button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
_timer.Tick += new GT.Timer.TickEventHandler(timer_Tick);
int x;
int y;
oledDisplay.SimpleGraphics.Clear();
_test = _test + "X";
Font font = Resources.GetFont(Resources.FontResources.NinaB);
int width = (int)oledDisplay.Width;
int height = (int)oledDisplay.Height;
font.ComputeTextInRect(_test, out x, out y, 0, 0, width, height, Bitmap.DT_WordWrap);
oledDisplay.SimpleGraphics.DisplayTextInRectangle(_test, 0, 0, (uint)width, (uint)height,
GT.Color.Red, font);
oledDisplay.SimpleGraphics.DisplayText("X: " + x.ToString() + " Y: " + y.ToString(), font, GT.Color.Blue, 0, 113);
void button_ButtonPressed(Button sender, Button.ButtonState state)
if (button.IsLedOn)
_timer.Stop();
_timer.Start();
button.ToggleLED();
