I’m porting and making some “improvements” to Fabien Royer’s AnalogJoystick class (http://netduinohelpers.codeplex.com/). However, after making some changes I found that I could no longer run the program. It sits in the “Preparing to deploy assemblies to the device…” state forever until canceled or times out. Not really anything in the output. I’ve narrowed it down to one change that seems to be the hold up but I can’t make sense of why it shouldn’t work. All I basically did was add a reference of one property inside of another. See the X property below. If you want entire project, let me know where to put it.
namespace Joystick_Tutorial
/// <summary>
/// AnalogJoystick class from the netduino Helpers project (http://netduinohelpers.codeplex.com/) by Fabien Royer.
/// This class interfaces with an analog x, y joystick such as a the ones found in game controllers (PS/2, Xbox 360, etc.)
/// Tested with a thumb joystick by Sparkfun: http://www.sparkfun.com/products/9032
/// Datasheet: http://www.p3america.com/pp/pdfs/802.PDF
/// </summary>
public class AnalogJoystick : IDisposable
protected AnalogIn Xinput;
protected AnalogIn Yinput;
/// <summary>
/// Returns the current raw x position
/// </summary>
/* WORKS */
public int X
get
return Xinput.Read();
/* DOESN'T WORK
public int X
get
var direction = XDirection;
switch (direction)
case Direction.Negative:
return Xinput.Read(); // +XTrim.Negative;
case Direction.Positive:
return Xinput.Read(); // +XTrim.Positive;
/// <summary>
/// Returns the current raw y position
/// </summary>
public int Y { get { return Yinput.Read(); } }
// Upper end of of the user-defined value range for the X and Y axis
protected int MaxRange;
// Defines a relative area around the center of the joystick where the values fluctuate constantly and should be treated as 'center'.
protected int CenterDeadZoneRadius;
/// <summary>
/// Auto-calibration min and max values defining the logical center of the X axis
/// </summary>
protected int XMinCenter { get; set; }
protected int XMaxCenter { get; set; }
/// <summary>
/// Auto-calibration min and max values defining the logical center of the Y axis
/// </summary>
protected int YMinCenter { get; set; }
protected int YMaxCenter { get; set; }
/// <summary>
/// Relative direction definitions
/// </summary>
public enum Direction
Center = 0,
Negative = -1,
Positive = 1
/// <summary>
/// Returns the relative direction in which the joystick is moving on the X axis
/// </summary>
public Direction XDirection
get
int tempX = X;
if (tempX >= XMinCenter && tempX <= XMaxCenter)
return Direction.Center;
if (tempX < XMinCenter)
return Direction.Negative;
if (tempX > XMaxCenter)
return Direction.Positive;
/// <summary>
/// Returns the relative direction in which the joystick is moving on the Y axis
/// </summary>
public Direction YDirection
get
int tempY = Y;
if (tempY >= YMinCenter && tempY <= YMaxCenter)
if (tempY < YMinCenter)
if (tempY > YMaxCenter)
public double Angle
get
return Trigo.Atan2(Y - 512, X - 512);
public double Amplitude
get
var x = X - 512;
var y = Y - 512;
return Trigo.Sqrt(x * x + y * y);
/// <summary>
/// Automatically determines the range of values defining the center for the X and Y axis.
/// Assumes that the joystick is at the center position on the X & Y axis.
/// Do not touch the joystick during auto-calibration :)
/// </summary>
/// <param name="centerDeadZoneRadius">A user-defined radius used to eliminate spurious readings around the center</param>
public void AutoCalibrateCenter(int centerDeadZoneRadius)
XMinCenter = X;
XMaxCenter = XMinCenter;
YMinCenter = Y;
YMaxCenter = YMinCenter;
for (var I = 0; I < 100; I++)
var tempX = X;
var tempY = Y;
XMinCenter = tempX;
XMaxCenter = tempX;
YMinCenter = tempY;
YMaxCenter = tempY;
XMinCenter -= centerDeadZoneRadius;
YMaxCenter += centerDeadZoneRadius;
/// <summary>
/// Expects two analog pins connected to the x & y axis of the joystick.
/// </summary>
/// <param name="xAxisPin">Analog pin for the x axis</param>
/// <param name="yAxisPin">Analog pin for the y axis</param>
/// <param name="minRange"></param>
/// <param name="maxRange"></param>
/// <param name="centerDeadZoneRadius"></param>
public AnalogJoystick(Cpu.Pin xAxisPin, Cpu.Pin yAxisPin, int minRange = 0, int maxRange = 1023, int centerDeadZoneRadius = 10)
MaxRange = maxRange;
Xinput = new AnalogIn((AnalogIn.Pin)xAxisPin);
Xinput.SetLinearScale(minRange, maxRange);
Yinput = new AnalogIn((AnalogIn.Pin)yAxisPin);
Yinput.SetLinearScale(minRange, maxRange);
AutoCalibrateCenter(centerDeadZoneRadius);
/// <summary>
/// Frees the resources allocated for reading values from the analog joystick
/// </summary>
public void Dispose()
Xinput.Dispose();
Xinput = null;
Yinput.Dispose();
Yinput = null;
