Wify RS 21 module and SerialL2 camera problem
Hi, i cant get to work wifi rs21 and serial L2 camera together, any time i run the timer to get NewImageready i have the following exception:
 #### Exception System.InvalidOperationException - 0x00000000 (6) ####
 #### Message: Failed to read all of the bytes from the port.
 #### Gadgeteer.Modules.GHIElectronics.SerialCameraL2::ReadBytes [IP: 002f] ####
 #### Gadgeteer.Modules.GHIElectronics.SerialCameraL2::ReadFrameBuffer [IP: 0076] ####
 #### Gadgeteer.Modules.GHIElectronics.SerialCameraL2::UpdateStreaming [IP: 003d] ####
A first chance exception of type 'System.InvalidOperationException' occurred in GTM.GHIElectronics.SerialCameraL2.dll
Is there any solutions?
You seen this https://www.ghielectronics.com/community/forum/topic?id=14685 ?
@ njbuch -
No i didn’t see this thread… Anyway i didn’t find any direct solutions… Did you?
It seem like wifi rs21 and sercamL2 are not compatible… Does anybody have a workaround?
I found the same problem in this thread: https://www.ghielectronics.com/community/forum/topic?id=16573
Any comments from GHI? If these modules are not compatible why there is no information on the product page?
@ Alex Bilityuk - Unfortunately the issue I described on https://www.ghielectronics.com/community/forum/topic?id=16573&page=3#msg191537 is still a problem in NETMF itself. NETMF 4.4 might alleviate it.
@ John -
Do you know the release date of 4.4?
@ andre.m -
Ok! Thank you!
