Hi.
We’re trying to use an Olimex Mod-Wifi UEXT module on a FEZ-Cobra board, by running following (coming from standard GHI documentation, updated a little to provide the missing parameter on WiFi.Enable() method):
/// Add these libraries to your project's References
/// System
/// Microsoft.SPOT.Hardware
/// Microsoft.SPOT.Net
/// GHIElectronics.NETMF.System
/// GHIElectronics.NETMF.Net
using System.Net;
namespace WiFi_Example4._0
static public bool wifi_event = false;
static public bool wifi_last_status = false;
static public bool network_is_read = false;
static public ManualResetEvent NetworkAvailablityBlocking = null;
NetworkChange.NetworkAvailabilityChanged += new NetworkAvailabilityChangedEventHandler(NetworkChange_NetworkAvailabilityChanged);
if (!WiFi.IsEnabled)
WiFi.Enable(WiFi.HardwareModule.ZG100M_Compatible, SPI.SPI_module.SPI2,
(Cpu.Pin)FEZ_Pin.Digital.UEXT10,
(Cpu.Pin)FEZ_Pin.Digital.UEXT5,
(Cpu.Pin)FEZ_Pin.Digital.UEXT6);// EMX DevSys
// WiFi settings
NetworkInterface[] netif = NetworkInterface.GetAllNetworkInterfaces();
Wireless80211 WiFiSettings = null;
for (int index = 0; index < netif.Length; ++index)
if (netif[index] is Wireless80211)
WiFiSettings = (Wireless80211)netif[index];
if (WiFiSettings.Ssid != "my_ssid")
WiFiSettings.Ssid = "my_ssid";
WiFiSettings.PassPhrase = "my_pass";
WiFiSettings.Encryption = Wireless80211.EncryptionType.WPA;
Wireless80211.SaveConfiguration(new Wireless80211[] { WiFiSettings }, false);
NetworkAvailablityBlocking = new ManualResetEvent(false);
if (!WiFi.IsLinkConnected)
Debug.Print("Waiting for WiFi link!");
NetworkAvailablityBlocking.Reset();
while (!NetworkAvailablityBlocking.WaitOne(5000, false))
Debug.Print("WiFi link is not available yet! Wrong AP settings?");
Debug.Print("Still waiting.");
break;
Debug.Print("WiFi link is ready!");
Debug.Print("Enable DHCP");
try
if (!WiFiSettings.IsDhcpEnabled)
WiFiSettings.EnableDhcp();// This function is blocking
WiFiSettings.RenewDhcpLease();// This function is blocking
network_is_read = true;
Debug.Print("Network settings:");
Debug.Print("IP Address: " + WiFiSettings.IPAddress);
Debug.Print("Subnet Mask: " + WiFiSettings.SubnetMask);
Debug.Print("Default Getway: " + WiFiSettings.GatewayAddress);
Debug.Print("DNS Server: " + WiFiSettings.DnsAddresses[0]);
catch
Debug.Print("DHCP Faild");
Debug.Print("Test DNS");
try
IPHostEntry myIP = Dns.GetHostEntry("www.ghielectronics.com");
if (myIP != null)
Debug.Print(myIP.HostName + ": " + myIP.AddressList[0].ToString());
catch
Debug.Print("Faild to Get the host entry of the FQN from DNS server!");
// This call back will be called when any change occures on Ethernet cable connection or WiFi physical link.
// Also it reports PPP connection status if PPP is enabled.
static void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
if (e.IsAvailable)
if (WiFi.IsLinkConnected)
if (wifi_last_status != true)
wifi_last_status = true;
NetworkAvailablityBlocking.Set();
if (wifi_last_status != false)
But WiFi.IsLinkConnected is always false!
Of course, we double checked for mispelled SSID, password and encryption type used.
Any suggestions?
