Hi all,
I was running into a very strange problem. I’ve built a simple setup with Spider, GPS module and WiFi RS21 module. The implemented webserver functionality simply responds to request by sending the last position received.
On my laptop another project is running that sends a request to the spider and plots the current position based on the respond onto a map. To communicate with the board I’ve simply started a hosted network on the notebook. The WiFi RS21 connects to it and as soon this has happened starts the webserver and starts responding to requests.
This worked like a charm for several days. The longest test period was about 5 hrs of continues operation.
Now - same untouched configuration, same .net project - it won’t connect to the hosted network anymore. First I was afraid that I’ve received some silly MS update which restricts something here. But I also cannot connect to my normal WLAN network I’m connected to with all my stuff here.
I’ve built a new setup and .net project reduced to spider and WiFi RS21 only. Last option I’ve tried was to change everything to adhoc based connection initiated by the spider/Wifi. I was able to connect to it and to ping it.
So, now I’m completely confused here. Someone with same experiences here? Any ideas?
Cheers
MorphMeta
