WIFI RS21 Image transfer
Hi to everyone, i use a Serial Camera L2 and WIFI RS21 modules for transferring captured image form camera to PC.
I use a WebEvent responder.Respond() method to transfer the captured image. I use Raptor (2014 R5 SDK, 4.3.6 firmware).
Here is wifi, camera and WebServer initialization code:
Responder pictoPCResponder; //responder handle
public byte[] capturedata = null;//Image buffer
                InitializeCamera();
                Thread t = new Thread(new ThreadStart(() =>
                InitializeWIFIRS21();
           t.Start();
                this.r_capture_timer = new GT.Timer(1000);
                this.r_capture_timer.Tick+=this.r_capture_timer_Tick;
 private void InitializeCamera()
            Debug.Print("Camera Initialization...");
            serialCameraL2.ImageResolution = SerialCameraL2.Resolution.QVGA;
            serialCameraL2.StartStreaming();
            Debug.Print("Camera Initialized");
 private void InitializeWIFIRS21()
            WiFiRS9110.NetworkParameters ADHOC_PARAMS = new WiFiRS9110.NetworkParameters();
            ADHOC_PARAMS.Channel = 10;
            ADHOC_PARAMS.Key = KEY;
            ADHOC_PARAMS.Ssid = SSID;
            ADHOC_PARAMS.SecurityMode = WiFiRS9110.SecurityMode.Wep;
            ADHOC_PARAMS.NetworkType = WiFiRS9110.NetworkType.AdHoc;
            wifiRS21.NetworkInterface.Open();
            wifiRS21.NetworkInterface.EnableStaticIP("192.168.0.18", "255.255.255.0", "192.168.0.18");
            wifiRS21.NetworkInterface.StartAdHocNetwork(ADHOC_PARAMS);
            ipaddress = wifiRS21.NetworkInterface.IPAddress;
            wifiRS21.NetworkDown += wifiRS21_NetworkDown;
            wifiRS21.NetworkUp += wifiRS21_NetworkUp;
        void wifiRS21_NetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
            Debug.Print("network UP");
            Thread.Sleep(3000);
            RunServer();
        void wifiRS21_NetworkDown(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
            Debug.Print("network down");
 public void RunServer()
            WebEvent pictopc = WebServer.SetupWebEvent("pictopc");
            pictopc.WebEventReceived += pictopc_WebEventReceived;
            WebServer.StartLocalServer(ipaddress, 80);
        void pictopc_WebEventReceived(string path, WebServer.HttpMethod method, Responder responder)
            r_capture_timer.Start();
            pictoPCResponder = responder;
After i send http request from PC, pictopc_WebEventReceived event handler start the timer for image preparation and response to http client:
 void r_capture_timer_Tick(GT.Timer timer)
            Debug.Print("Preparing image");
                if (serialCameraL2.NewImageReady)
                    Debug.Print("Image ready");
                    timer.Stop();
                    capturedata = serialCameraL2.GetImageData();
                    if (capturedata != null)
                       pictoPCResponder.Respond(capturedata, "image/bmp");
                        Debug.Print("Image data is null");
I have the folowing problems:
1)This is the main problem. I could transfer image to PC only when i load in vs 2013 debuger, if i load assemblies in release mode and don’t attach debugger, the image is not transfering.
2) Very very slow serialCameraL2.NewImageReady event. Aprox… 30 seconds up to 1 minute before image is ready.
3) How stable is Ad-Hoc connection between PC and WIFI RS21, can i use it for image transferring purpose?
Does anybody meet the same problem?
Hello Alex,
Did you try to inactivate Firewall and Virus Scanner?
Hi, RoSchmi!!!
Thank you for reply! I don’t have a virus scanner, also my firewall is deactivated.
I really had a more fast and stable transfer with an old RN XV and your brilliant driver. But i have to switch for RS 21 because i need a multiple connections, that RN XV doesn’t support.
I would modify your code like this. Does not solve your Problem but it runs with Debugger and without Debugger
public partial class Program
        private const string Key = "E8430A5EDB";
        private const string SSID = "YourSSID";
        private string ipaddress;
        GT.Timer r_capture_timer;
        GT.Networking.WebEvent defaultEvent;
        GT.Networking.WebEvent pictopc;
            r_capture_timer.Tick +=r_capture_timer_Tick;
            InitializeCamera();
            ADHOC_PARAMS.Key = Key;
            Thread.Sleep(3000);
            RunServer();
            defaultEvent = WebServer.DefaultEvent;
            defaultEvent.WebEventReceived += defaultEvent_WebEventReceived;
        void defaultEvent_WebEventReceived(string path, WebServer.HttpMethod method, Responder responder)
            string requestedURL = path;
            switch (path)
                case "Beautiful.jpg":
                        // Get the image from the resources in the byte array
                        byte[] document = Resources.GetBytes(Resources.BinaryResources.Beautiful);
                        responder.Respond(document, "images/jpeg");
                    break;
                default:
                        string content = "<html><body><h1>Hello, could not be found....</h1></body></html>";
                        byte[] bytes = new System.Text.UTF8Encoding().GetBytes(content);
                        responder.Respond(bytes, "text/html");
                        break;
            Debug.Print("Default WebEvent received");
          //  r_capture_timer.Start();                  //?
          //  pictoPCResponder = responder;   //?
@ Alex Bilityuk -
I did same perliminary tests, may be that starting new threads for the responses does the trick:
            SendResponseInThread mySendResponseInThread = new SendResponseInThread(path, method, responder);
            Debug.Print("Default WebEvent received. Thread: " + Thread.CurrentThread.GetHashCode().ToString());
        class SendResponseInThread
            public SendResponseInThread(string pPath, WebServer.HttpMethod pMethod, Responder pResponder)
                Thread sendThread = new Thread(new ThreadStart(() =>
                    SendResponse(pPath, pMethod, pResponder);
                sendThread.Start();
            private void SendResponse(string _path, WebServer.HttpMethod _method, Responder _responder)
                switch (_path)
                            _responder.Respond(document, "images/jpeg");
                        break;
                    case "BigImage.jpg":
                            byte[] document = Resources.GetBytes(Resources.BinaryResources.BigImage);
                        break;
                    default:
                            _responder.Respond(bytes, "text/html");
                        break;
@ RoSchmi -
Thank you very much for a code sample… wifi module stopped working for unknown reasons, i will try this code as soon as i figure out the wifi problem and let you know the results…
Any luck with this issue? I am getting the same results using a Hydra and SerialCameraL2.
Is 1 frame per minute the expected performance?
