I am new to programming the WiFi RS21 + Raptor + SDK 2014 R5. First trial connections seem to work good, but now I have some questions concerning the driver’s features for which I couldn’t find answers in the documentation or the forum so far:
Can I find the source for the GTM.Module.NetworkModule class, from which the WiFiRS21-class is derived, somewhere (would be maybe a means to answer some of the below questions myself), or is it proprietary to GHI ?
Are the Power Save Modes “Sleep” and “Standby” (see RS-9110 datasheet) accessible by the WiFiRS21-class / -driver or is there any way to achieve them ?
Is a there a means provided to completely turn WLAN on and off at HAL-/driver-level or do I have to do this by hardware ?
Is so-called ESS-reassociation (transition to a stronger channel w/ same SSID in a multi AP environment) inherently handled by the driver or do I have to take care about that “manually” ? If manually, would it be possible to do this without temporarily disconnecting?
Is it correct, that normally there should be no need for wifiRS21.NetworkInterface.RenewDhcpLease(), because the DHCP server would do this (if the client stays connected)? I am a bit unsure if and when to use this method, e.g. considering DHCP Lease Process | Microsoft Learn, especially because I couldn’t find any property containing an info about when DHCP lease expires. Do I have to handle this?
Would be great, if one or some of the more experienced could help me with the above items, which are currently “blank spots” to me.
