I’m having trouble getting the WiFi RS21 module to connect to my wireless network.
I’ve gone through all the previous posts here and they all give the same results: it will always throw a JoinException with the message “Authentication Failure”
Here is the code I am using to attempt the connection:
public partial class Program
#region Confidential
string SSID = "mySSID";
string PASSWORD = "wpa2-aes-passkey";
#endregion
GT.Timer Kick;
WiFiRS9110.NetworkParameters network;
wifiRS21.NetworkInterface.Open();
wifiRS21.NetworkInterface.EnableDhcp();
wifiRS21.NetworkInterface.EnableDynamicDns();
wifiRS21.UseThisNetworkInterface();
NetworkChange.NetworkAddressChanged += NetworkChange_NetworkAddressChanged;
NetworkChange.NetworkAvailabilityChanged += NetworkChange_NetworkAvailabilityChanged;
Kick = new GT.Timer(5000);
Kick.Tick += Kick_Tick;
Kick.Start();
void Kick_Tick(GT.Timer timer)
Debug.Print("Attempt to Join");
try
WiFiRS9110.NetworkParameters[] results = wifiRS21.NetworkInterface.Scan(SSID);
if (results != null && results.Length > 0)
network = results[0];
network.Key = PASSWORD;
wifiRS21.NetworkInterface.Join(network);
catch (Exception ex)
//Debug.Print("Exception : " + ex.Message);
Debug.Print("*** " + network.Ssid + " ***");
Debug.Print("Channel: " + network.Channel);
Debug.Print("Key: " + network.Key);
Debug.Print("Network Type: " + network.NetworkType);
Debug.Print("Physical Address: " + network.PhysicalAddress.ToString());
Debug.Print("Rssi: " + network.Rssi);
Debug.Print("Security Mode: " + network.SecurityMode);
private void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
Debug.Print("Network Availability : " + e.IsAvailable.ToString());
private void NetworkChange_NetworkAddressChanged(object sender, EventArgs e)
Debug.Print("Address : " + wifiRS21.NetworkInterface.IPAddress);
I’ve tried joining the network with no password on the connection and I still will get an Authentication Failure when attempting to connect. Has anybody had any success fixing this issue?
Regards,
Darwin
