WiFi issue with EMX frimware V4.1.5.1
Thanks to mrPositive, we discovered a little bug in the new SPI driver that affects WiFi SPI clock. WiFi will not work with EMX firmware V4.1.5.1 as expected.
We are working on a bug fix and will be available in the next SDK release.
If you need to use WiFi now you need to use firmware V4.1.5.0
http://www.ghielectronics.com/downloads/NETMF/GHI%20NETMF%20v4.1%20SDK(4.1.5.0).zip
Is this message still valid with the new sdk release of today?
No. It should be fixed.
