WIFI connection to router
Hello, I try to get a conncetion to a wlan router with the wifi module. The module is connected to the emx dev-board as descriped in manual.
I took the code from the library: http://www.ghielectronics.com/downloads/NETMF/Library%20Documentation/html/7481f4d9-b4bc-f53d-e6bb-3a1ae861c9ef.htm
First I want to try without encryption:
 wifiSettings.Encryption = Wireless80211.EncryptionType.None;
 wifiSettings.Authentication = Wireless80211.AuthenticationType.Open;
But every time after following codeline, the emx freezes:
 Wireless80211.SaveConfiguration(new Wireless80211[] { wifiSettings }, false);
On the lcd display following mesage appears:
[italic]Build Date:
Oct 15 2010
09:52:48
cp=0x200000df
pc=0x00050943
lr=0x00050947
sp=0x4000f638[/italic]
Please update your firmware and tinybooter to latest then start new project and let us know if you see errors please.
…start by entering GHI loader and using E to erase all.
Ok, I reset the whole board with the tinybooter.ghi and after that with the emx firmware files (all versions from 15th october).
But same again.
Now I tried new board with a new wifi module and a clean programm with only the code I mentioned before. As you can see at the picture, the module don’t want to connect?
The wlan router is a Thomson TG585 v7 and works fine with my laptop (Win7).
Config on router setup menu:
802.11 b/g
None Encryption
Now it looks like it works, I have changed the Wifi.Enable method:
  //WiFi.Enable(SPI.SPI_module.SPI2, (Cpu.Pin)33, (Cpu.Pin)19);
   WiFi.Enable(SPI.SPI_module.SPI1, EMX.Pin.IO2, EMX.Pin.IO26);// EMX DevSys
[url]http://www.ghielectronics.com/downloads/NETMF_WiFi/NETMF%20WiFi%20User%20Guide%202.pdf[/url]
