ahalim
1
I am looking at this sample code from the tutorial page:
https://docs.ghielectronics.com/software/tinyclr/tutorials/wifi.html
The comment says this code is for fez portal.
Would it work for fezduino? Are there any changes I need to make for it to work?
thanks
Not much changes needed, just the pins. This should also work with the bit and feather.
class Program
static void Main()
var enablePin = GpioController.GetDefault().OpenPin(GHIElectronics.TinyCLR.Pins.SC20100.GpioPin.PA8);
enablePin.SetDriveMode(GpioPinDriveMode.Output);
enablePin.Write(GpioPinValue.High);
var cs = GpioController.GetDefault().OpenPin(SC20100.GpioPin.PD15);
SpiNetworkCommunicationInterfaceSettings netInterfaceSettings = new SpiNetworkCommunicationInterfaceSettings();
var settings = new SpiConnectionSettings()
ChipSelectLine = cs,
ClockFrequency = 4000000,
Mode = SpiMode.Mode0,
ChipSelectType = SpiChipSelectType.Gpio,
ChipSelectHoldTime = TimeSpan.FromTicks(10),
ChipSelectSetupTime = TimeSpan.FromTicks(10)
netInterfaceSettings.SpiApiName = SC20100.SpiBus.Spi3;
netInterfaceSettings.GpioApiName = SC20100.GpioPin.Id;
netInterfaceSettings.SpiSettings = settings;
netInterfaceSettings.InterruptPin = GpioController.GetDefault().OpenPin(SC20100.GpioPin.PB12);
netInterfaceSettings.InterruptEdge = GpioPinEdge.FallingEdge;
netInterfaceSettings.InterruptDriveMode = GpioPinDriveMode.InputPullUp;
netInterfaceSettings.ResetPin = GpioController.GetDefault().OpenPin(SC20100.GpioPin.PB13);
netInterfaceSettings.ResetActiveState = GpioPinValue.Low;
var networkController = NetworkController.FromName("GHIElectronics.TinyCLR.NativeApis.ATWINC15xx.NetworkController");
WiFiNetworkInterfaceSettings wifiSettings = new WiFiNetworkInterfaceSettings()
Ssid = "ssid",
Password = "password",
// wifiSettings.Address = new IPAddress(new byte[] { 192, 168, 1, 122 });
// wifiSettings.SubnetMask = new IPAddress(new byte[] { 255, 255, 255, 0 });
// wifiSettings.GatewayAddress = new IPAddress(new byte[] { 192, 168, 1, 1 });
// wifiSettings.DnsAddresses = new IPAddress[] { new IPAddress(new byte[]
//{ 75, 75, 75, 75 }), new IPAddress(new byte[] { 75, 75, 75, 76 }) };
wifiSettings.IsDhcpEnabled = true;
wifiSettings.IsDynamicDnsEnabled = true;
wifiSettings.TlsEntropy = new byte[] { 0, 1, 2, 3 };
networkController.SetInterfaceSettings(wifiSettings);
networkController.SetCommunicationInterfaceSettings(netInterfaceSettings);
networkController.SetAsDefaultController();
networkController.NetworkAddressChanged += (NetworkController sender, NetworkAddressChangedEventArgs e) =>
var ipProperties = sender.GetIPProperties();
var address = ipProperties.Address.GetAddressBytes();
Debug.WriteLine("IP: " + address[0] + "." + address[1] + "." + address[2] +
"." + address[3]);
networkController.NetworkLinkConnectedChanged += NetworkController_NetworkLinkConnectedChanged;
networkController.Enable();
// Network is ready to used
private static void NetworkController_NetworkLinkConnectedChanged(NetworkController sender, NetworkLinkConnectedChangedEventArgs e)
private static void NetworkController_NetworkAddressChanged(NetworkController sender, NetworkAddressChangedEventArgs e)
"." + address[3]);
ahalim
3
Great. Thanks! I will give it a try.
