i have a serial monitor program for my fez spider , but debugging it , it only starts after adding or deleting a breakpoint in vs2010 ?
New project? Latest SDK?
new projekt, sdk 4.1.
Very unusual. Maybe try 4.2
so here’s a sequence, can you tell us how it works? Deploy your code, that contains debug.print statements. Once it’s running, unplug device. Open MFDeploy. Connect device. Then, in MFDeploy, connect to the USB device and see if your debug print statements appear; I am expecting them to.
here is the code, it is a simple bridge between a usbserialport and a usbhost. with a sniffer on the cdc serialport to read the trafffic on the computer in a serial program, i used serialport in vb.net from codeplex in a serial port next to debugging on 1 usb port.
program generated
// <auto-generated>
// This code was generated by the Gadgeteer Designer.
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
// </auto-generated>
using Gadgeteer;
using GHIElectronics.NETMF.USBClient;
using GHIElectronics.NETMF.USBHost;
namespace SerialUsbClientmodule
public partial class Program : Gadgeteer.Program
// GTM.Module defintions
static Gadgeteer.Modules.GHIElectronics.UsbSerial usbSerial;
Gadgeteer.Modules.GHIElectronics.UsbClientDP usbClient;
//Gadgeteer.Modules.GHIElectronics.UsbHost usbHost;
//Important to initialize the Mainboard first
Mainboard = new GHIElectronics.Gadgeteer.FEZSpider();
Program program = new Program();
program.InitializeModules();
program.ProgramStarted();
program.Run(); // Starts Dispatcher
private void InitializeModules()
// Initialize GTM.Modules and event handlers here.
usbClient = new GTM.GHIElectronics.UsbClientDP(1);
//usbHost = new GTM.GHIElectronics.UsbHost(3);
usbSerial = new GTM.GHIElectronics.UsbSerial(8);
using System.Text;
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
// http://www.tinyclr.com/codeshare/entry/335
//static USBC_CDC cdc = USBClientController.StandardDevices.StartCDC_WithDebugging(); // adds cdc next to debug on usb
//static USBH_SerialUSB serialUSBHost; // adds usbhost as serial port = declares cdc
private Thread USBSerRX, USBSerTX;
static byte HostorClient;
static bool jilles = true;
usbSerial.Configure(115200,
GT.Interfaces.Serial.SerialParity.None,
GT.Interfaces.Serial.SerialStopBits.One,
8);
usbSerial.SerialLine.ReadTimeout = 0;
usbSerial.SerialLine.Open();
// declare usbhost
USBHostController.DeviceConnectedEvent += DeviceConnectedEvent;
USBSerRX = new Thread(clienttohost);
USBSerTX = new Thread(hosttoclient);
USBSerRX.Start();
USBSerTX.Start();
private static void clienttohost()
int NumberOfBytesToRead ;
byte[] readInputBuffer = new byte[256];
HostorClient = 1;
while (jilles)
NumberOfBytesToRead = usbSerial.SerialLine.Read(readInputBuffer, 0, 256);
if (NumberOfBytesToRead > 0)
serialUSBHost.Write(readInputBuffer, 0, NumberOfBytesToRead);
serialUSBHost.Flush();
cdcwrite1(readInputBuffer, NumberOfBytesToRead, HostorClient);
private static void hosttoclient()
while (jilles)
byte[] UsbHostReadBuffer = new byte[256];
byte HostorClient = 2;
int NumberOfReadBytes;
NumberOfReadBytes = serialUSBHost.Read(UsbHostReadBuffer, 0, 256);
if (NumberOfReadBytes > 0)
usbSerial.SerialLine.Write(UsbHostReadBuffer, 0, NumberOfReadBytes);
cdcwrite1(UsbHostReadBuffer, NumberOfReadBytes, HostorClient);
private static void cdcwrite1(byte[] readinputbuffer, int bufferlength, byte HostorClient)
if (USBClientController.GetState() != USBClientController.State.Running)
Debug.Print("Waiting to connect to PC...");
byte[] output = new byte[bufferlength + 1];
output[0] = HostorClient ; // 1 gives terminal the info that it is coming from usbserial 2 from usbhost
Array.Copy(readinputbuffer, 0, output, 1, bufferlength);
cdc.Write(output, 0, output.Length);
static void DeviceConnectedEvent(USBH_Device device)
Debug.Print("Device connected");
switch (device.TYPE)
case USBH_DeviceType.Serial_FTDI: // FTDI connected
serialUSBHost = new USBH_SerialUSB(device, 115200,
System.IO.Ports.Parity.None, 8,
System.IO.Ports.StopBits.One);
serialUSBHost.Open();
//serialUSBThread = new Thread(SerialUSBThread);
//serialUSBThread.Start();
break;
case USBH_DeviceType.Unknown: // SiLabs but not recognized
// force SiLabs
USBH_Device silabs = new USBH_Device(device.ID,
device.INTERFACE_INDEX,
USBH_DeviceType.Serial_SiLabs, device.VENDOR_ID,
device.PRODUCT_ID, device.PORT_NUMBER);
serialUSBHost = new USBH_SerialUSB(silabs, 9600,
break;
} // void
indeed it works with netmf 4.2 , i am glad i ordered one serial client to much because the cdc isnt supported anymore on the usb debug port, my laptop has only ther usb ports.
// <auto-generated>
using Gadgeteer;
namespace UsbToSerialNetMf42
// GTM.Module definitions
Gadgeteer.Modules.GHIElectronics.UsbClientDP usbClientDP;
Gadgeteer.Modules.GHIElectronics.UsbSerial usbSerial1;
usbClientDP = new GTM.GHIElectronics.UsbClientDP(1);
usbSerial1 = new GTM.GHIElectronics.UsbSerial(4);
using GHI.Premium.USBHost;
using GHI.Premium.USBClient;
using GHI.Premium.System;
static bool Hconnected = false;
timer.Tick +=<tab><tab>
timer.Start();
8);
//usbSerial.SerialLine.ReadTimeout = 0;
usbSerial1.Configure(115200,
8);
usbSerial1.SerialLine.Open();
// declare usbhost
USBSerRX.Start();
USBSerTX.Start();
} // programstarted
private void clienttohost()
int NumberOfBytesToRead;
HostorClient = 1;
while (Hconnected)
public void hosttoclient()
while (Hconnected)
private void cdcwrite1(byte[] readinputbuffer, int bufferlength, byte HostorClient)
output[0] = HostorClient; // 1 gives terminal the info that it is coming from usbserial 2 from usbhost
usbSerial1.SerialLine.Write(output, 0, output.Length);
Hconnected = true;
break;
// force SiLabs
break;
} // void
