Hi:
I am building a program with several threads, and have been seeing strange things. So I isolated the strangeness to the following code which can run as a complete program and demonstrates what is happening.
I spin a new thread, with a sleep function, then print the time and thread ID. After 10 cycles I call debug.gc(false), and the thread ID changes back to the main thread. Is this a known behavior, by design, or a bug?
The reason I am doing this is because the larger program sometimes shows signs of a memory leak, and I wanted to use this as a tool to debug.
First the code, then the printout:
Imports GT = Gadgeteer
Imports GTM = Gadgeteer.Modules
Imports Gadgeteer.Modules.GHIElectronics
Namespace GadgeteerApp2
Partial Public Class Program
Public Sub ProgramStarted()
Debug.Print("Program Started on managed thread id " & Thread.CurrentThread.ManagedThreadId.ToString)
Dim ClockThread As New Thread(AddressOf PostTimeThread)
ClockThread.Start()
End Sub
Dim i As Integer = 0
Private Sub PostTimeThread()
Do While True
PostTime1()
Thread.Sleep(999)
i += 1
If i = 10 Then Debug.GC(False)
Loop
End Sub
Private Sub PostTime1()
Dim s As String = i.ToString & ": " & DateTime.Now.ToString
Do While s.Length < 20
s = s & " "
Loop
' display.WriteHere(s, 0, 0) 'works a few times then corrupts the diaplay and freezes the Raptor
s = s & ", on managed thread " & Thread.CurrentThread.ManagedThreadId
Debug.Print(s)
End Sub
End Class
End Namespace
Using mainboard GHI Electronics FEZRaptor version 1.0
Program Started on managed thread id 0
0: 06/01/2011 00:21:40, on managed thread 4
1: 06/01/2011 00:21:41, on managed thread 4
2: 06/01/2011 00:21:42, on managed thread 4
3: 06/01/2011 00:21:43, on managed thread 4
4: 06/01/2011 00:21:44, on managed thread 4
5: 06/01/2011 00:21:45, on managed thread 4
6: 06/01/2011 00:21:46, on managed thread 4
7: 06/01/2011 00:21:47, on managed thread 4
8: 06/01/2011 00:21:48, on managed thread 4
9: 06/01/2011 00:21:49, on managed thread 4
GC: 1msec 275736 bytes used, 66830028 bytes available
Type 0F (STRING ): 948 bytes
Type 11 (CLASS ): 10140 bytes
Type 12 (VALUETYPE ): 1056 bytes
Type 13 (SZARRAY ): 3780 bytes
Type 03 (U1 ): 156 bytes
Type 04 (CHAR ): 876 bytes
Type 07 (I4 ): 1332 bytes
Type 0F (STRING ): 48 bytes
Type 11 (CLASS ): 1368 bytes
Type 15 (FREEBLOCK ): 66830028 bytes
Type 16 (CACHEDBLOCK ): 72 bytes
Type 17 (ASSEMBLY ): 29544 bytes
Type 18 (WEAKCLASS ): 96 bytes
Type 19 (REFLECTION ): 168 bytes
Type 1B (DELEGATE_HEAD ): 360 bytes
Type 1D (OBJECT_TO_EVENT ): 168 bytes
Type 1E (BINARY_BLOB_HEAD ): 223140 bytes
Type 1F (THREAD ): 1152 bytes
Type 20 (SUBTHREAD ): 96 bytes
Type 21 (STACK_FRAME ): 1632 bytes
Type 26 (WAIT_FOR_OBJECT_HEAD): 48 bytes
Type 27 (FINALIZER_HEAD ): 72 bytes
Type 31 (IO_PORT ): 108 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 3084 bytes
10: 06/01/2011 00:21:50, on managed thread 0
11: 06/01/2011 00:21:51, on managed thread 0
12: 06/01/2011 00:21:52, on managed thread 0
13: 06/01/2011 00:21:53, on managed thread 0
14: 06/01/2011 00:21:54, on managed thread 0
15: 06/01/2011 00:21:55, on managed thread 0
16: 06/01/2011 00:21:56, on managed thread 0
