Where to debug print to?
a lot of gadgeteer code has code like
Debug.Print(“Network is Up”);
but i understand the code is transferred to the ie fez spider and runs there alone without communication with vs2010 , like code running in windows or iis .
where is the debug print going to be displayed ? on the ts 35 ?
vS output window
but on debugging the code is transferred to the spider. i only see output until vs transfers the program to the spider.
If the VS debugger is not attached, it is not displayed anywhere
Are you doing debug or deploy?
i just do the debug like a normal program F5. i have a relaese option no deploy option .
out put gives this :
a lot o library transfers and then
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.1\le\Gadgeteer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.1\le\Gadgeteer.WebServer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Touch.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.System.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.USBHost.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Camera\NETMF 4.1\le\GTM.GHIElectronics.Camera.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.Net.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.IO.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZSpider\NETMF 4.1\le\GHIElectronics.Gadgeteer.FEZSpider.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Ethernet_J11D\NETMF 4.1\le\GTM.GHIElectronics.Ethernet_J11D.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Display_T35\NETMF 4.1\le\GTM.GHIElectronics.Display_T35.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Button\NETMF 4.1\le\GTM.GHIElectronics.Button.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Users\jilles\Documents\Visual Studio 2010\Projects\ipaddress\ipaddress\bin\Debug\le\ipaddress.exe’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.Http.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.W5100.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.1\le\Gadgeteer.WebClient.dll’, Symbols loaded.
The program ‘[1] Micro Framework application: Managed’ has exited with code 0 (0x0).
@ wetlip - what code are you running?
indeed when i hit F5 or start button debug i get a very short time in the output window deploying… and then the normal debug info above
where is that to be changed ?
this to test the jd11d .
a lot of debug.print , but how to get it in vs ?
my t35 screen has as info debug:usb1
namespace ipaddress
     public partial class Program
    {     Debug.Print("Program Started");
           ethernet.UseStaticIP("10.10.10.10","255.255.255.0","10.10.10.1",new String[]{"10.1.10.1"});
           // ethernet.UseDHCP();
            ethernet.NetworkUp += new GTM.Module.NetworkModule.NetworkEventHandler(ethernet_NetworkUp);
            ethernet.NetworkDown += new GTM.Module.NetworkModule.NetworkEventHandler(ethernet_NetworkDown);
        void ethernet_NetworkDown(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
            Debug.Print("Network is Down");
        void ethernet_NetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
            Debug.Print("Network is Up");
            Debug.Print("IP Address: "+ethernet.NetworkSettings.IPAddress.ToString());
            Debug.Print("Subnet Mask: " + ethernet.NetworkSettings.SubnetMask.ToString());
            Debug.Print("Gateway: " + ethernet.NetworkSettings.GatewayAddress.ToString());
            Debug.Print("DNS Server: " + ethernet.NetworkSettings.DnsAddresses[0].ToString());
Using code tags will make your post more readable. This can be done in two ways:[ol]
Click the “101010” icon and paste your code between the
 tags or...
Select the code within your post and click the "101010" icon.[/ol]
(Generated by QuickReply)
The Debug.Print output will show up where all those .dll messages you posted are. Those dll loaded message are normal and a part of the debugging process.
I would suggest that once you device starts up, hit the clear button in the debug section. You can also put break points in your code to ensure that those lines are actually executed.
Not sure what that means. You need to build in debug mode and then use F5 to debug. You should see all your debug.print stuff in the Visual Studio output window.
Pete
i get this from output Micro Framework device Deploment
Incrementally deploying assemblies to device
Deploying assemblies for a total size of 265740 bytes
Assemblies successfully deployed to device.
i changed the projekt of the startesguide spider with two debug lines "camera takes picture " and “picture displayed” but no debug info in output window vs201’.
it must be a setting in the ide.
You did press the button, right?
i am one step further adding a breakpoint at the end } of void button_ButtonPressed it is hit while pressing button attached to spider, but no debug info in output window vs2010
 void button_ButtonPressed(Button sender , Button.ButtonState state)
          camera.TakePicture();
          Debug.Print("camera takes picture");
That is weird. Try to restart Visual Studio and replug your device.
it is the sameafter restarting these are my debug settings. nowhere something like “show code generated debug messages” , i use 2010 profesional
and after checking, normal not micro framework solutions dont either, in vs 2012 beta either , i will ask in th vs2010 ide forums. i have subversion installed as plugin.
How did you get these?
[quote]‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded 'C:\Program Files (x86)\Microsoft .N…[/quote]
solution
in menu vs2010 tools debugging general : i had checked debug info to immediate window. unchecking it gives al debug.prints in output window. i must say i have never used debug print until now, i always use breakpoints to examine the code
http://social.msdn.microsoft.com/Forums/en/Vsexpressvb/thread/89cba401-9939-4918-8253-adbcb8482986
