the wait for in September almost a year is over, thanks for all the good work in getting it out.
For the modules I’d be interrested in are an xbee module, a relay module, a sensorboard module (temp, pressure, humidity, etc) would be nice. A board with a bigger touch LCD would be nice as well.
BTW since it’s kind of the same HW can’t we hook up the Cobra 7" LCD ? But a bigger one would be nicer …
Were can I get some more details on the WIFI module tech specs ?
Thank you in advance and keep the good thing going !!!
Some general purpose digital I/O. At least 8inputs / 8 outputs. I saw some input buttons, but most any useful project is going to need to read some digital inputs (sensors anyone?) and set some outputs.
Button Module (4 buttons + PWM RGB LED) Socket 8 or 11 on Spider
Power Module (LiPo Power Supply w/ Charger & Power Level Indicator) Most Sockets
Proto Module (N/A) ALL Sockets
With any luck I’ll have them available before the Spider starts shipping.
I’m totally new to this and have only worked with Arduino in the past. But this is finally a big improvement and I’m looking forward playing around with Gadgeteer!
The things I’d like to see added though, and its a pitty its not in there from the beginning, are:
Can you connect the sensors, and motors that have 3 pin connectors? That immediately would open up a lot more modules to use with the gadgeteer mainboard.
