Hello All,
I have recently started a new job in which I have inherited some .NET micro framework code to edit. The code is intended to run on the G30 SoC.
I am confused by the Configuration Sector. In my program I only write to it once and I write a single byte yet somehow it contains 16384 bytes. Furthermore, it seems to always exist even when I clear the application from the device using Fez.
In my experience a processor’s configuration is no more than a handful of bytes determining things like which pins use interrupts and which clock dividers are active, etc. So I am at a loss.
Can anyone explain to me what the Configuration Sector of the G30 is?
Much appreciated.
