As long as you have a nice set of magnifying glasses (I use a custom set of 3x bi-focals with plain glass on top) 0805 is easy to use. Even 0603 at a push is easy with these glasses on.
0603’s are ok to do by hand and 0402 is a little tricky but as Justin said, surfce tension works a treat. Once i stopped worrying about exact placement of 0402 and trusted the solder paste to pull it straight life got a little easier. Now all i have to worry about is my hot air gun accidentally blowing the components off the board as i forgot that it was set too high on the blower :(. I’ve done this far to many times to have not learned by now
