I have a Panda II with a ProtoShield… I am workong on CAN project. On the protoshield I have my MCP2551 all wired up…I have the 4.1.8.0 firmware loaded…
I copied and pasted the CAN demo code from the wiki into my project…
Without making any changes, I am having problems accessing the CAN class.
static CAN.Message[] msgList;
Throws the following error:
[quote]The type or namespace name ‘Message’ does not exist in the namespace ‘CAN’ (are you missing an assembly reference?)
[/quote]
I made sure that I have the GHIElectronics.NETMF.Hardware reference in place, as well as the FEXPanda_II_GHIElectronics.NETMF.FEZ.
I can get around the error by using the full, long reference for all variables. Like
static GHIElectronics.NETMF.Hardware.CAN.Message[] msgList;
That will compile, but it’s really long… What am I missing?
Please post the complete code here.
Here is the “broken” code:
// Messages list
// Set the system time. CAN messages will have a time stamp
Utility.SetLocalTime(new DateTime(2011, 2, 14, 0, 0, 0));
int T1, T2, BRP;
// These numbers were calculated using the calculator on this link:
// http://www.kvaser.com/can/protocol/index.htm
// We used the very first value from the calculator output
// Bitrate 250Kbps
// CLK = 72 Mhz, with BRP = 12 -> 6Mhz CAN clock
// 6Mhz/250Kbps = 24 TQ
// T1 = 16 minus 1 for sync = 15
// T2 = 8
// 15 + 1 + 8 = 24 TQs which is what we need
// uncomment to use this bit timing
//BRP = 12;
//T1 = 15;
//T2 = 8;
// Bitrate 125Kbps
// CLK = 72 Mhz, with BRP = 24 -> 3Mhz CAN clock
// 3Mhz/125Kbps = 24 TQ
// T2 = 8
BRP = 24;
T1 = 15;
T2 = 8;
// For 500Kbps you can use BRP=6 and for 1Mbps you can use BRP=3 ...and so on
// Use channel 1
CAN can = new CAN(CAN.Channel.Channel_1, (uint)(((T2 - 1) << 20) | ((T1 - 1) << 16) | ((BRP - 1) << 0)));
// create a message list of 100 messages
msgList = new CAN.Message[100];
for (int i = 0; i < msgList.Length; i++)
msgList[i] = new CAN.Message();
// example for sending one message
// msg ID
msgList[0].ArbID = 0x55;
msgList[0].Data[0] = 1;
msgList[0].Data[1] = 2;
msgList[0].Data[2] = 3;
msgList[0].Data[3] = 4;
msgList[0].Data[4] = 5;
msgList[0].Data[5] = 6;
msgList[0].Data[6] = 7;
msgList[0].Data[7] = 8;
// Send the 8 bytes for example
msgList[0].DLC = 8;
msgList[0].IsEID = false;
msgList[0].IsRTR = false;
// Send one messages
int numberOfMessagesPosted = can.PostMessages(msgList, 0, 1);
// subscribe to events
can.DataReceivedEvent += new CANDataReceivedEventHandler(can_DataReceivedEvent);
can.ErrorReceivedEvent += new CANErrorReceivedEventHandler(can_ErrorReceivedEvent);
// sleep forever
static void can_DataReceivedEvent(CAN sender, CANDataReceivedEventArgs args)
Debug.Print(">>> can_DataReceivedEvent <<<");
// read as many messages as possible
int count = sender.GetMessages(msgList, 0, msgList.Length);
for (int i = 0; i < count; i++)
Debug.Print("MSG: ID = " + msgList[i].ArbID + " at time = " + msgList[i].TimeStamp);
static void can_ErrorReceivedEvent(CAN sender, CANErrorReceivedEventArgs args)
Debug.Print(">>> can_ErrorReceivedEvent <<<");
switch (args.Error)
case CAN.Error.Overrun:
Debug.Print("Overrun error. Message lost");
break;
case CAN.Error.RXOver:
Debug.Print("RXOver error. Internal buffer is full. Message lost");
break;
case CAN.Error.BusOff:
Debug.Print("BusOff error. Reset CAN controller.");
sender.Reset();
break;
Here is what I had to do to get around the problem. This compiles, but the read event never triggers.
namespace Example
// Messages list
int T1, T2, BRP;
// Bitrate 250Kbps
// T2 = 8
//BRP = 12;
//T1 = 15;
//T2 = 8;
// Bitrate 125Kbps
// T2 = 8
BRP = 24;
T1 = 15;
T2 = 8;
// Use channel 1
GHIElectronics.NETMF.Hardware.CAN MYcan = new GHIElectronics.NETMF.Hardware.CAN(GHIElectronics.NETMF.Hardware.CAN.Channel.Channel_1, (uint)(((T2 - 1) << 20) | ((T1 - 1) << 16) | ((BRP - 1) << 0)));
msgList = new GHIElectronics.NETMF.Hardware.CAN.Message[100];
msgList[i] = new GHIElectronics.NETMF.Hardware.CAN.Message();
// msg ID
msgList[0].DLC = 8;
MYcan.DataReceivedEvent += new CANDataReceivedEventHandler(can_DataReceivedEvent);
MYcan.ErrorReceivedEvent += new CANErrorReceivedEventHandler(can_ErrorReceivedEvent);
// sleep forever
Debug.Print("Waiting for wakeup call");
Debug.Print("How did I get here");
static void can_DataReceivedEvent(GHIElectronics.NETMF.Hardware.CAN sender, CANDataReceivedEventArgs args)
static void can_ErrorReceivedEvent(GHIElectronics.NETMF.Hardware.CAN sender, CANErrorReceivedEventArgs args)
switch (args.Error)
case GHIElectronics.NETMF.Hardware.CAN.Error.Overrun:
break;
case GHIElectronics.NETMF.Hardware.CAN.Error.RXOver:
break;
case GHIElectronics.NETMF.Hardware.CAN.Error.BusOff:
sender.Reset();
break;
Some progress… I changed the bit timing to
BRP = 12;
T1 = 15;
T2 = 8;
and at least now I’m getting bus errors… ???
It’s better than nothing…
Nenver mind… Figured it out… I’m a totall noob :-[
I am happily receiving CAN bus events and I got my references sorted out… User Error ;D
