Some months ago, we developed 3 new iot products based on G80 processor.
We had no problems with prototypes, and with minor changes we arranged a small production which was also successful.
Now we arranged a larger production (200 pieces), and we can´t deploy the firmware to 80 of them (40% aprox).
The weird part is that we can upload Config.ghi and Firmware.ghi smoothly, but when we try to deploy hex file via FezConfig 40% of them fails (Failure: Device is not connected or not Responding).
We can even re-enter in “GHI Bootloader Interface” mode, and upload ghi files without problems, but the failure rate in deploying hex files is too high.
We have tried this in 2 PCs, Windows 7 and Windows 10, but results are the same.
You can boot products in Bootload mode via LDR pins and stay there all day if you want. So we think there are no problems in G80, power supply, oscilator and usb connections.
In fact, if you reboot in normal mode, device is discovered by Windows as G80. The problem is 40% of them wont load hex firmware with Fez Config, and of course wont run final application.
