I´m trying to make a webserver with cerberus, enc28 and framework 4.3.
I have tried different options.
When i try to connect it with dhcp never have an ip.
For this reason i am working with fixed ip.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using GHI.Networking;
namespace GadgeteerApp7
public partial class Program
private static EthernetENC28J60 netif;
// FEZ Cerberus Socket and Pins assigments
var socket = GT.Socket.GetSocket(1, true, null, null);
var pinINT = socket.CpuPins[3];
var pinRESET = socket.CpuPins[4];
var pinSPI_CS = socket.CpuPins[6];
netif = new EthernetENC28J60(SPI.SPI_module.SPI1, pinSPI_CS, pinINT, pinRESET);
netif.Open();
//netif.EnableDhcp();
netif.EnableStaticIP("192.168.0.100", "255.255.255.0", "192.168.0.1");
while (netif.NetworkInterface.IPAddress == "0.0.0.0")
Debug.Print("Waiting for DHCP");
Thread.Sleep(250);
Debug.Print("Network IPAddress : " + netif.NetworkInterface.IPAddress);
var allIf = NetworkInterface.GetAllNetworkInterfaces();
WebServer.SetupWebEvent("hello").WebEventReceived += OnWebEventReceived;
WebServer.DefaultEvent.WebEventReceived += DefaultEventOnWebEventReceived;
WebServer.StartLocalServer(netif.IPAddress, 80);
private void DefaultEventOnWebEventReceived(string path, WebServer.HttpMethod method, Responder responder)
throw new NotImplementedException();
private void OnWebEventReceived(string path, WebServer.HttpMethod method, Responder responder)
responder.Respond("Hello");
If i connect the ENC28 in program.gadgeteer designer i have the next error:
Excepción no controlada del tipo ‘System.InvalidOperationException’ en GHI.Networking.dll
Información adicional: This interface type is already created.
if i dont connect the ENC28 in program.gadgeteer designer i have the next error in :
Excepción no controlada del tipo ‘System.Net.Sockets.SocketException’ en Microsoft.SPOT.Net.dll
I have tried it with the ENC28 in sockets 1, 5 and 6.
Did you know where can i found a complete example with this configuration??
I have tried differents but ones for spider, others for hydra, others for framework 4.2, etc…
thanks in advance,
