Hello
I want to put a large file on my SD card (connected to raptor) for download using a webserver based on netmf 4.3. I used codeplex webserver43 and patched responder.cs as it was mentioned in lots of threads…
So, the main problems are:
- there is no handling on name of downloading file. How can I set the name of downloading file?
and
*2) as you know there is a limit on making byte array because of memory… So, I have to split my file to some parts and then send them to client. This is my code:
FileStream fileStream = new FileStream(fileAddress, FileMode.Open, FileAccess.Read);
long TotalPackages = fileStream.Length / PackSize;
for (int j = 0; j < TotalPackages; j++)
FileData = new byte[PackSize];
fileStream.Read(FileData, 0, PackSize);
// first packet
if (j == 0)
{ responder.FileRespond(FileData, false);}
else{responder.FileRespond(FileData, true);}
byte[] FileData1 = null;
if (fileStream.Length % PackSize != 0)
{long TDG = fileStream.Length / PackSize;
int length = unchecked((int)(fileStream.Length - (TDG * PackSize)));
FileData1 = new byte[length];
fileStream.Position = unchecked((int)(TDG * PackSize));
fileStream.Read(FileData1, 0, length);
responder.FileRespond(FileData1, true);}
responder.closeConnection();
fileStream.Close();
and I changed the responder class as follow:
public void FileRespond(byte[] data, bool firstPacket)
if (data != null)
{ webEvent.ContentType = "application/octet-stream";
webEvent.ResponseData = data;}
mySendResponse(firstPacket);
internal void mySendResponse(bool firstPacket)
try
{ BinaryResponseTemplate template = this.webEvent.ComputeResponse();
if (!firstPacket)
if (template.Header != null && template.Header.Length > 0)
this.ClientSocket.Send(template.Header, 0, template.Header.Length, SocketFlags.None);
if (template.Content != null && template.Content.Length > 0)
this.ClientSocket.Send(template.Content, 0, template.Content.Length, SocketFlags.None);
catch (Exception e)
Debug.Print("Exception sending web event response (connection was probably terminated) ");
public void closeConnection()
try
this.ClientSocket.Close();
catch { }
but, when second packet is going to be send this error will be appeared:
I know it probably means that the client has closed the connection… So what can I do?
