Trying to write some code for my FEZ Raptor. Did bootloader and TinyCLR update, so can use it now, but each time I’m debugging - getting the following error after deploying (this is VS crash and VS closing after this):
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.IOException
at GHIElectronics.TinyCLR.Debugger.Request.Wait()
at GHIElectronics.TinyCLR.Debugger.Engine.SyncRequest(GHIElectronics.TinyCLR.Debugger.WireProtocol.OutgoingMessage, Int32, Int32)
at GHIElectronics.TinyCLR.Debugger.Engine.ResolveAllAssemblies()
at GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.CorDebugProcess.LoadAssemblies()
at GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.CorDebugProcess.UpdateAssemblies()
at GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.CLREventsBreakpoint.Hit(Debugging_Execution_BreakpointDef)
at GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.CorDebugProcess.BreakpointHit(Debugging_Execution_BreakpointDef)
at GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.CorDebugProcess.DrainBreakpoints()
at GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.CorDebugProcess.OnCommand(GHIElectronics.TinyCLR.Debugger.WireProtocol.IncomingMessage, Boolean)
at GHIElectronics.TinyCLR.Debugger.Engine.NotificationThreadWorker()
at System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart()
What it could be, please?
