He throw lot of errors, cause he don’t understand the standard character to start a comment???
After using the ancient style ‘REM’ this was fixed, but still more errors there.
Is this a silly bug, or is VB not really working?
I not only select netMF cause I should be able to use the existing VB code of my project (former runs under XP) and can start doing business as usual.
Not to ask a stupid question, but was that the single quote ’ or the ` . They look similar, but the second is not actually the single quote used as a comment in VB.
sorry about the delay, was busy with other project.
I send the code,
It is the ‘Serial Communication Demo’ from the documentation, converted to VB with a code converter, just to have a nice starting point.
I replaced the single quotes with ‘REM’ just to see, if there were more issues. Unfortunately, there is a generated file also having comments, and so I stopped because this would be a never ending story.
So, the question about using just the wrong character is also answered, I hope that the code generator uses the correct one … hihi.
I also think, that the compiler used is the standard VB, and as I converted some notNETMF projects with this converter without problems over the years, I was totally astonished about that issue. It is really funny.
With best regards
Gerhard
Seems that the trick filename.zip.png doesnt work.
Ok, will send the Project, please tell me how.
PS: Hard to send a zip file, so how can I send a Project?
